Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Where is that listed? Their own site seems to call it Triad...
https://www.coldsteel.com/ad-10.html
"No folder would be complete without a reliable locking mechanism, so we have incorporated Andrew’s famous Tri-Ad® lock."
So, do all recent cold steel knifes (ones that are still in production) use tri-ad or there are ones using regular lockback?
What do you mean “not going to have time to put a pin in anyway” ?Gotta admit I was never interested beyond general curiosity, but just read about it here.
https://www.coldsteel.com/tri_ad_lock
Personally I'm good with a regular lockback because I don't use a folder for things other than folders were/are intended for. If I had to use it for last ditch SD emergency I'm not going to have time to put a pin in anyway.
I could see this in a BOB or Emergency kit when you might not be able to fit a fixed blade. So it does have a place. Generally I'd just use a fixed blade though...preferably.
Baffles me why cold steel even decide to do backlock or linerlock with secondary locks when they could just do triadlock. The additional mechanism actually gives it a bit more complexity and it can’t be cheaper to produce.Most are Tri-Ad, but there are some that are not. For example, the Double Safe Hunter and Bush Ranger Lite are lockbacks that have a secondary lock. And the new 911 is a liner lock, as are the Ti-Lites. Look through their catalog...it is very clear which ones have the Tri-Ad lock.
It’s just a normal backlock with secondary safety.Bit off topic, but can anyone explain the “rocker lock” found on some of the budget CS knives? The one with a secondary safety? How is that different from the Tri-Ad lock?
