Yes to both. Jigaloo will lubricate the pivot and rust prevent the blade. The Jigaloo on the pivot will probably last 3 to 6 months, but spray the blade every couple of weeks or after hard use.
I use my George Tichbourne folder pretty well daily. I lubricated the pivot last August and it is still smooth and dust free. The blade is 440C stainless, so it doesn't need any treatment.
Try Jigaloo, it is not expensive, but is extremely versatile. Don't spray it on cheap, thin plastic though as it can melt it.
Looking for something new and possibly better, I checked the Jigaloo website.
I found this:
If swallowed. Call a doctor immediately. Do NOT induce vomiting without instruction from medical personnel.
If sprayed in eyes. Immediately flush area thoroughly with water, remove any contact lenses and hold your eyelids open while continuing to flush eyes for about 15 minutes.
If sprayed on skin. Rinse the area well with water.
If inhaled. Go outside in the fresh air immediately.
CAUTION
Contains: methylene chloride, perchloroethylene, isobutane,
and propane.
Contents and fumes may catch fire. Container may explode if heated. May irritate eyes and skin
Keep away from flames, pilot lights, and sparks, including electric motors. Use only in a well-ventilated area. Do not swallow or get in eyes or on skin. Do not breathe fumes. Do not puncture or incinerate container. Do not store at temperatures above 120°F. Keep out of reach of children.
Some plastics and painted surfaces may react. Please check by testing a small area on the surface before spraying the entire object.
WARNING
This product contains chemicals known to the State of California to cause cancer.
____________________________________________________________________________
This seems like a heckuva set of warnings.
I guess the stuff must be pretty good!.
