What do you consider sharp? If you had a stone of similar finish, do you think it would be better or worse than the strop? What do you classify as hard use?
Depends: For my work knife, sharp enough to easily slice through two layers of brown paper wrapper about 30 inches long. I open around 24 to 30 bags per 12 hour shift...thank goodness today is my last 12 as business demand just isn't there, back to 8's woohoo...if the knife is dull it tears rather than slices and can take several times as long to perform this task...I don't have the time to waste nor the patience trying to get a dull knife to cut through the wrapper.
I could achieve similar results using a stone of similar abrasive/polishing grit but my strop sits in the drawer of my side table aside my couch. I easily pull it out while watching TV...a couple minutes of passes and voila restored to sharpness for my next day of work.
For my EDC/hiking knives: They can shave the hair off of my arm and/or easily slice, without grabbing, through telephone book paper cut into 3x5 inch pieces...for ease of testing.
I've recently started using black compound and am surprised by how this compound improves the edge while stropping. I usually used just green...knowing it is more polish than abrasive. After reading much on forums regarding black compound I bought a stick at Sears for 3 bucks and used it on the untreated side of my two sided strop. Wow what a difference it makes. It does add sharpness and has really made touching up an edge much better, especially my work knife.
I added this compound after buying a Bark River DPH, which has a convex grind. In previous posts I talked about adding a bevel as I was worried about maintaining the convex edge...my stropping skills were not that good and I would dull a freshly sharpened knife about half the time when stropping with only green compound.
I took the time, after reading some forum replies, etc., to practice my technique and the improvement has been significant. I can now, with care and patience, improve the quality of a hone sharpened knife to a decent degree using the strop as a finishing mode. I can also quickly restore a knife that has dulled just a bit with a couple of minutes using the black then green compounds.
Here are a couple of pics of my "work" knife. You can see my thumb mark where I hold the knife during use. The material is very abrasive as it is a filtering medium for our water treatment system.
This knife: BM H&K Plan D is only several months old and used only for work cutting open the bags I described earlier.
