Is Swiss Army Knife's pen ink waterproof?
Hi all,
Is Swiss Army Knife's pen ink waterproof? After it dries, will water on the paper make it smudge or will it hold?
Thanks!
Vic pen should act just like most ball point pen, they shouldn't fade or feather like fountain pen.
But just out of curiosity, I did this little test. And after couple of minutes, there is no side of feathering/fading, and it looks fine even after I've tried to smudge it.
Depends on the fountain pen ink. I have a couple that are unaffected by water after it dries on cellulose (wood) paper. One I have is even pretty much unaffected by industrial strength bleach after it dries*! 😳
(*per a couple you tube reviews where they tested against water, bleach, and other things in an attempt to lift the ink from a page.)
@doaman
The ink Victorinox uses is a standard ballpoint ink, so it's waterproof.
Like any other ballpoint pen ink, it will fade over time when/if exposed to sunlight. (a sign in the window, or on a exterior door, for example.)
I had a Vic "Signature" (same as the SD Classic, but has a blue retractable pen instead of the toothpick) that I carried for about 12 years.
Admittedly, I did not use the pen much (like I said; "blue ink". I needed black and red ink at work.) However, even after 11 or 12 years of daily carry, and occasional use of the pen, the original ink cartridge/refill wrote fine. It never dried out ... unlike some of my other ballpoints that could be ... "difficult" ... to start ... sometimes requiring a bit of heat from my Zippo/BiC or a match before they would write.
There’s a simple solution to the problem of fading or smudging ink. Or pens that don’t write properly. Use a pencil and sharpen it with your favourite pocket knive. Apart from perhaps a disposable BIC, I haven’t bought or used any pen in years. But the Victorinox pen should act like any other ballpoint pen.
