It's great to ask questions...that is how you learn and there are a great bunch of folks to learn from here. The process if starting with annealed material is to get your blank close to net with all holes included, heat treat which has different techniques and temperatures for different steels. I will describe stainless or air hardening steel process since that is what I am more familiar with. ATS-34 for example, I wrap in foil then I heat treat it at 1950 F and rapid air quench, this will make the steel hard and somewhat brittle and can chip easily. This takes us to the tempering or drawing back of the steel which causes it to be less brittle, you loose a very little bit of hardness but it is needed to make the blade tough and stand up to use. I then double temper for example I will put the blades in at 850 F for 2 hours let cool to room temperature then go back in the oven at 850 F for another 2 hours. If I cryogenic treat the blades, I do it between heat treat and temper. This is a very simple explanation with out getting into martinizing, grain growth etc., I don't think you are ready for that yet. You have talked about 440C and 01 in your posts and they are 2 different animals, let us know what steel you have chosen and folks here can help. I heat treat stainless for other makers and if you need that service, let me know. Again heat treat, quench, temper is the order of things. Others can help on the edge treatment and clay for hamons etc. for the high carbon steels.
Hope this helps!
Jim
