As the title states, is a .22LR the most versatile caliber for urban/wilderness survival?
22LR ammo is relatively inexpensive, lightweight, and can be purchased in extreme quantities without a problem. The round can also be used in both rifles or handguns, adding to it's versatility.
22LR is capable of taking all small game, and even deer with the right shot placement. Of course it's not legal to take deer with a .22LR, but in a desperate situation where you are just trying to keep alive and not starving to death, it's unlikely that legality will be a major concern in your mind. After all, humans are about the same size or slightly larger then the average deer, and they can certainly be killed with a 22LR.
What about against people that may be desperate or hungry enough to want to loot your supplies or other valuables? Well, you are probably thinking a .22LR is not what you want for this, and in general I would agree, but then I read this blog about someone living in Argentina and his experiences living in a country basically going through 'a significant depression'. He has this to say about the .22LR:
"Then there’s something I’ve seen done a lot, specially in farms and such, and is the need to fire a few warning shots to send trespassers, thieves and poachers away. This can happen almost on daily basis and I see the wisdom there in using a cheap round like 22LR, and that’s what most farmers and ranchers use most of here. 3 or 4 warning shots a day means over 1000 rounds a year. Better to make that 22LR. The semi auto 22lR carbine is also accurate for long range shooting in case they fire back. Anyone wounded at a considerable distance will most likely just leave."
In his blog here, he recommends that you carry and have access to other higher caliber firearms, but makes note that you will probably use your .22LR more then anything else.
http://ferfal.blogspot.com/search/label/Firearms
So do you agree or disagree with the .22LR being the most versatile round for urban/wilderness survival?
