Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I got mine used for like fifty bucks about seven years ago. Put a ceramic platen liner on it and ran it hard until I replaced it this summer. Worked great for me all those years...
They have been disco'd. They pop up on Craigslist every now and then, though they tend to disappear fairly quickly if under $100.Same.
I think they have been discontinued. I haven't seen a new one listed anywhere for a few years now.
I managed to snag a 1/2hp two wheel older model for $65 of CL, and it was the third I tried for. I missed the first two, a three wheel and a 1/3hp newer model.
Keep in mind that the stated HP rating isn't accurate running HP, it is peak HP. My 1/2hp, probably sits around 1/3 while running, but it is OK for now.
J jalcon : What state are you located in? Maybe someone that upgraded has one sitting idle in your area.
The closest that I can think of might be a two wheeled grizzly, but they to be around $500ish, but once you are in that range, other 2x72s start to come into the equation.Yeah I figured Craigslist was the best bet. If there is anything out there comparable in that same price range, let me know. I am in southcentral PA..
I hope the OP found resolution and I'm not imposing. If I am, please disregard. Is there any hope/improvements for this unit?
https://m.grainger.com/mobile/product/DAYTON-Belt-Disc-Sander-6Y945?fc=PDAP&analytics=altItems
Thank you. I'm sure any kind of a VFD would cost way too much. I've had this unit for about 7-8 years and I've hardly used it. I got a great deal on it hoping for that day when I retire from my job and I can slow the world down and do some things I've always wanted to do like make my first knife. A feller can dream."IF" you can find a way to slow it down from 4400 SFPM belt speed to perhaps 1,000 to 1200 SFPM belt speed for use with finer grit belts it might do ok. With 4400 SFPM belt speed it will be for 36 to 80 grit belts and rough grinding. All in all, I'd think the 2X42 would be a good bit better than a 1X30" grinder. You could do rough grinding, then finish with sandpaper..... lots of sandpaper {g}
