Is There An Order To Taking a Take-Apart Apart?
pjsjr
Trying to make scales for the 112.
Need to take the frame apart...
Take a look at post #26 if you have not already.
As you can see in your photo the frame & lock bar are riveted in place. However, you can rotate the frame to do what you want to do Sir.
Thanks you John, I see that now. Sorry about the duplicate post, I'll edit it out.
Take some long, spare #2X56TPI screws, preferably with a socket heads, chuck them up in a portable hand drill, and spin grind a point on each with either a wheel or a belt. Screw these into the Aluminum scales from the backside and press the new wooden scales onto the protruding points to mark the “clearance” holes. You can even clamp the wooden scales to the Aluminum scales and screw the pointed marking screws into the wood.
Thank you, Norm, just what I needed to know.
