JB Clear Weld Failure. I don't think I did anything wrong (doesn't mean I didn't)
HPD
I had a scale come off while attaching a Corby bolt this afternoon. The epoxy isn't that old, I spread it evenly and used spring clamps so as to not overtighten (there was dried epoxy on both pieces). I placed my handle in a vice and while I was screwing in a Corby bolt at the hole near the ricasso, the scale popped off at the liner. This isn't the fist time this has happened. Lucky I reattached everything with regular JB Weld and the Corby bolts were successfully mounted. It's out in the garage drying.
Does anyone have a recommendation for a better quick-setting epoxy, and has anyone else experienced this with JB Clear Weld or any other similar product? I haven't had this happen with any other product. Any insights would be appreciated, and I realize that maybe I'm doing something wrong and it isn't necessarily the fault of the product.
I’ve never had the JB clear weld fail before. There are a few different types of clear weld if I’m not mistaken, it wasn’t the one designed for plastics was it?
Even though I’ve never had it fail I tend to only use JB clear weld for personal knives and test knives, since I can just run to any store in my area and pick it up that day to use.
  • Like
Reactions: HPD
Jb weld clear is a 5 minute two part epoxy. Fine for attaching liners to scales...but not great for attaching scales to the tang. Use a slower setting epoxy. I have settled on west system g flex or blade bond 24 hour epoxy.
Just today I was able to peel a liner off some desert ironwood that I had used jb weld clear on.
I use JB Plastic Welder if I need a lighter color glue line; it's about a 30 min set time and dries a light tan/cream color. I've had the JB Clear Weld pop on me before a few times. I usually use JB Kwik Weld on my other handle scales, I've removed wood scales with it and the wood split and the epoxy was still stuck to the tang.
  • Like
Reactions: HPD
Are the liners G10? I use a lot of G10 liners and they need to be sanded well with absolutely no gloss left on the surface.
Yes, they are G-10. The ones I purchased came with the surfaces already roughened. I suspect the epoxy I used just isn't ideal for knife making.
Excellent. Maybe the clear weld isn't good at taking lateral stresses.
Looks like it probably wasn't me. I will give the G-flex a try. Thanks to all for your responses.
Even if the surfaces are already rough it helps to sand or sandblast them again immediately before gluing. Something to do with the surface energy on a molecular level.
