About JB Weld and Guards - Part 1
I'm quite sold on the JB Weld also. I learned the technique from Jerry Fisk circa 1996 and have been using it since. I don't know how many years Jerry had been using it before he taught me. I believe Jerry picked up the technique from Harvey Dean, and I don't know how many years Harvey had used it before sharing it with Jerry. I've never had any problems with it and neither has Jerry. We both still employ this technique. I assume that Harvey does as well.
I should mention that it's not the JB Kwik that I use though. I use the standard JB Weld. Here's the specs on each.
JB Kwik
Properties -- lbs/psi
Tensile Strength: 2100
Adhesion: 1800
Flex Strength: 7320
Tensile Lap Shear: 1040
Shrinkage: 0.0%
Resistant to 300º F
JB Kwik sets in 4 minutes and cures fully in 4 hours
JB Weld
Properties -- (lbs/psi)
Tensile Strength: 3960
Adhesion: 1800
Flex Strength: 7320
Shrinkage: 0.0%
Resistant to 500º F
JB Weld sets in 4-6 hours, and cures fully in 15-24 hours
The main difference in the two, other than the set time and curing time, is the tensile strength and resistance to heat.
Also worth mentioning is that (as stated in my tutorial) while JB Weld has tremendous bonding strength, the purpose is NOT to hold the guard on. That is done with a good fit. The guard stops on the back of the ricasso prevent the guard from moving forward, a good fitting, well bonded and pinned or bolted handle prevents the guard from moving backwards. A properly fitted guard slot (both in length and width) prevent the guard from moving up, down, side-to-side, or twisting.
The purpose of the JB Weld is to seal the joint. That is the same purpose of solder. If you are soldering guards for the primary purpose of holding them on or to hide small gaps, then your fit could use improvement. This is not to say that those who choose to solder are not getting a good fit. I just want everyone to understand that the purpose of both is to seal the joint from moisture and contaminants.
I was getting so many emails about the holding strength of JB Weld it was driving me nuts. I kept saying over and over, "It's not to hold it on , it's to seal the joint". When it finally came up to haunt me again in a thread on CKD many months ago, I decided okay dang it, let's see if the friggin' stuff will hold.
I fitted up a guard and sealed the joint with JB Weld. I let the thing cure over night. The next day made up a makeshift harness and slipped it on the guard.
Then I ran the makeshift harness through the a bowling ball bag with a 16 pound bowling ball inside, lifted up the works and started walking around the house with it. Here I am in the den.
Not a scientific test, but now I can say, yes JB Weld does a great job of holding the guard. BUT, the purpose is not to hold the guard on. It is to seal the joint.
