I think you nailed it. If I was Buck I wouldn't offer any take apart 110 or 112 parts unless there were threaded inserts. I can only imagine the amt of claims that could possibly happen.as tiguy7 mentioned earlier in the thread aluminum is touchy for screwing unscrewing stability without super extra care. could make warranty send in ridiculous and bad blood, for Buck, from customers not understanding that. assume would be better in a sturdier metal. except for weight of course.
Buck is not set up for the Physical Vapor Deposition of hard Ceramics. Cerakote is an organic (paint) coat with hard (Ceramic) particles added. The coating is thicker, is baked on, and can be applied to a larger variety of surfaces. I can steel a knife on a Ceramic coated blade but not a Cerakoted one.isn't Buck using Cerakote now? The other coatings I don't think exist anymore.
I get that. I don't think they are doing any coatings other than Cerakote.Buck is not set up for the Physical Vapor Deposition of hard Ceramics. Cerakote is an organic (paint) coat with hard (Ceramic) particles added. The coating is thicker, is baked on, and can be applied to a larger variety of surfaces. I can steel a knife on a Ceramic coated blade but not a Cerakoted one.
As a mechanic I know that working with aluminum is a tedious operation. The torque is critical that you don’t exceed the specifications. Aluminum is soft and can sheer much easier than brass or ns. That’s why I use blue assembly grade thread locker on everything so that even if it’s not torqued down the blue locker will keep it in place and can still be removed without applying heat. It’s a great product that can save you a lot of heartache and money.
As for myself I’m not interested in the take apart version, I’ll leave them as they are. I’d rather have the pinned assembly and it’s been very reliable for over 50 years. I guess cleaning would be more effective with the take apart model but I haven’t encountered any problems with the pinned version if done properly.
That wasn’t the point. I have also put threads in aluminum and I work on many aluminum parts and components very regularly but it can’t be over torqued or it will either shear threads, gauld the threads to seize to the screw. Or they are cross threaded and ruin both screw and the part. I’ve seen it countless times when a young inexperienced person tries to set a screw in aluminum. A trained and experienced person will know this but how many times can Buck repair or replace an aluminum knife that a novice has ruined before they have lost more than it’s worth. So the torque limit is critical and more so with aluminum and other soft metals. By using liquid thread lock On the screw it doesn’t even need to be tightened. It will set where you put it to. It’s Vibration resistant, temperature variations won’t cause it to loosen but it can still be removed with normal hand tools without using heat .I don't hesitate putting a machine thread in Aluminum if the hole is 3X as deep as it is wide.View attachment 1389003
Please forgive my ignorance, but what is that drop point blade from? Absolutely amazing! I really like that grind.
Didn't the Boone and Crockett set, 112 and 113 have that grind? I like it also.from a bcci 112 knife---dont remember which one....
