- Jan 7, 2017
just a few questions on stone handled knives
first I want to thank you for all your posts and instruction martial. I had run across your work about 3 years ago when I was getting started, and have "re-discovered" it as I do research in expanding my own work. I really want to market a stone handled liner lock one hand open/close . . .
questions
#1 stone on knives without rear bolster - Up to this point I have avoided making one, My fear is if it were dropped, it most likely would result in a ruined knife. The one thing I learned while taking an intarsia class, "hard as stone" has no meaning. Once the flat lap grabs the stone and flings it across the room, the resulting chip from the impact will cause extended labor or a design change. Would the bolster less design option be mostly for display knives and not for daily carry? your thoughts please. [my target market, price & finish is for use. Not up to collection quality - yet]
#2 I see you added the Buck 501 Squire - it has stainless bolsters - or are they not an issue with your custom diamond wheels? I have been afraid to try stainless with the fear of messing up, destroying or contamination my diamond wheels. Do you have reserved wheels used only on stainless? Or is it not that much different from blade steel, since we both grind on the spine, shaping both stone and steel at the same time with no problems. [although the spine on a 110 may not be "hardened" too much]
Thank you all
questions
Thank you all
