KA-BAR Heavy Bowie Review
I had the good fortune of winning a contest held by Moose: this is a review of the knife won in that contest.
KA-BAR heavy Bowie
14.25 inches OAL
9 inch clip point blade
.236 inch, 1085 steel
Black kraton handle with lanyard hole
Leather and cordura sheath was included
I must begin this review by confessing to two issues that will, undoubtedly, alter my opinion [of the knife] from the opinions of those who are most likely to purchase this particular knife.
I’ve never been a fan of really big knives – and this is a really big knife (in my opinion). I prefer blades around the 4 inch mark; with smaller being preferable to bigger. It isn’t that I hate the bigger knives; I just find, for my particular needs, that a smaller blade works best.
Due primarily to ongoing health issues, I do not spend much (if any) time camping, hiking, or roughing it in the wild. Because of this, my needs will likely be far different from those needs of the target audience (for this particular knife).
First Impressions:
WOW! – As in wow, that’s a big knife. I knew the knife was far larger than any of the knives I’ve ever owned, but seeing it in person really drove that point home.
I have owned one KA-BAR knife prior to this – I lost it many years ago – so I was expecting a high quality tool. This knife didn’t disappoint: the fit and finish is excellent. The knife came paper-shredding sharp and didn’t require any sharpening work on my part.
The sheath appears to be very functional, though I’m not a big fan of that type of sheath. Again, this is due to my particular needs and shouldn’t be taken as a slight against the sheath. I’m certain that those who need this type of knife would find the sheath to be exactly what is needed out in the more wild areas.
Performance:
In a prior posting, I had thanked Moose for his wonderful prize and promised to post a review once I had the opportunity to use the knife. Among the replies were requests for an evaluation of the knife’s performance when it came to batoning wood – something that I had never done previously.
I chose a section of wood that was roughly 6 inches in width, with an obvious knot as my test piece. Unfortunately the wood was soaked from the multiple days of rain we’ve been having – assumingly making the task more difficult.
I’ve split a lot of wood in my life, but never with a knife. (I’ve always used an axe or a splitting wedge) Even that lack of experience [on my part] didn’t seem to infringe upon the knife’s ability to split a relatively difficult piece of wood. I did use a wooden wedge to help keep the top gap open while I batoned the knife through the latter half of the selected log, but I don’t think that was “cheating” since I had used the knife to size the wedge prior to attempting the split.
Although I would prefer an axe (along with dry wood) when splitting logs, I was surprised at how well batoning [with the KA-BAR] actually works.
I also used the knife to cut a [roughly] 3 inch branch into lengths (another first for me). I found batoning the knife through the branch to be very efficient; only slightly less so than using an axe or hatchet. I do suspect that this method is probably safer than using an axe or a hatchet, simply because of the overall control.
Chopping the branch was considerably more difficult, but still a relatively easy task. The “hook” on the end of the handle makes it very easy to maintain control while chopping. (I really like that feature)
The knife performed very well when drilling holes in an old board I had lying around. I’m sure it would perform far better if I had any real experience with this task.
The knife excels at shaving curls on a stick of wood: I found it easy to control the knife and easy to control the curling of the wood.
I do tend to carve wood fairly frequently and while this knife could be used to carve wood, it wouldn’t be my first choice (simply due to the size of the knife). I think it would be an excellent choice for sharpening the tip of a make-shift spear, or even carving notches if a delicate touch isn’t really mandatory.
I tend to think of this knife as a smaller machete, so I used it as such. I “trimmed” back the excessive growth on my rose bushes and found that the knife works fairly well for this task. It easily sliced through all but the thickest branches [of the rose bushes] and made short work of that unpleasant job.
I forgot to take pictures of the Rose Bushes, so I took a picture of a sapling cut down with the Heavy Bowie. I'd guess that the sapling was around 3/4 of an inch wide and the Heavy Bowie felled it with one swipe.
Conclusion:
I like this knife a lot and would certainly buy one if I didn’t already own it. To me this knife is a general purpose tool: capable of doing almost any knife task well and exceeding at some tasks. Were I someone who regularly roughed it in the wild, I would certainly consider this knife a valuable member of my “must-have” tools. As it is, the knife will get plenty of use doing ordinary – albeit mundane – chores around my property.
The handle wins high praise in my opinion: it’s extremely comfortable and seems made with chopping in mind.
Despite some fairly heavy use, the blade held up extremely well. It wasn’t quite as sharp [after use] as it was new out of the box, but a few minutes of stropping took care of that. I was a bit hesitant to baton the knife - fearing I’d chip or roll the edge - but the blade had absolutely no damage after batoning it through several pieces of wood.
I also think the knife is built very well. It seems as though it is almost indestructible – barring purposeful intent to destroy it – and will almost certainly outlast me.
Not counting my lack of experience using a big knife, I could find no faults with the KA-BAR Heavy Bowie and highly recommend it to those who are looking at bigger knives. Heck, I’d recommend it to those who aren’t looking for a bigger knife.
I would also like to extend my thanks to Moose and KA-BAR - This knife is a truly wonderful prize.
Excellent review! I really love the reviews where people actually get out and do some work with the blade. I also really enjoyed how straight forward you were with things. I myself am not a woods expert either, so I like hearing you talk about your experience with batoning and things like that. Not that I'd use a knife to split wood for a cabin, but its good to see that it can both chop, baton, and make curls, which is everything you need for a fire.
I've been looking for a larger woods knife for when I go camping, and this just helped justify my desire for such a knife.
Thanks again :).
great review and great photos. I really want one of these (note: want, not need) and this review made that worse :)
Great review! I had a short love affair with the short model but have since used the BK7 when I want to carry a blade in that range. Now I need to get her out and play with it this weekend, thanks.
Nice review. This is a good lookign knife, and from what I've read, it certainly seems VERY capable.
Enjoy using her.
The Large Heavy Bowie is a nice knife for sure!! Makes a good Chef's knife in the kitchen and a good all around camp knife out in the field. Pair it with a smaller knife if you like, a Machete or Axe and a saw and you are good to go!
My wife got me this knife for my birthday last October. Any true knife lover would get a kick out of this knife for all that it delivers at its price.
The inner need in me called me to make a few modifications to the sheath. I think my works help to capture the spirit of what a bowie truly is...The original survival knife. Bowie was a frontiersman, and his knife was popular with his peers.
Since getting this knife, my wife also got me an esee junglas. While ”amazing” is an understatement for that blade, I still love and enjoy my Kabar LHB as much as when I got it.
And again, at its price, the knife is basically giving you its permission to be be thrust blade deep into big chores.
PS I meant to title this post ”Love this knife”
Cool review and nice knife. I wish it was made in the USA and I would get one.
While I prefer the overall build, and blade design of the Large Heavy Bowie, Cost wise, the Ontario SP5 is Made in the USA. But they are hard to find.
You can find the Marine Raider online for a few bucks more. It has a cross guard, and a saber grind (I prefer the Full Flat grind of the LHB).
The QC is good on the Kabar though. Taiwan's manufacturing seems to be more consistent than China's.
One highly underrated big knife. Trying to find a better knife within its price range AND quality would be a challenge. Sheath is pretty good too.
tooj's handle ergo's are perfect for heavy use.
