- Sep 16, 2002
I just received my new KMG with KBAC-27DVFD, and one of the first things I'm reading in the VFD manual (and it's mentioned numerous times) is that it's not recommended to be used on a GFCI circuit, and that 'special software is required.' Guess what kind of circuit is in my garage!?! I'm just wondering how big of an issue this may or may not be and/or what might happen using this as is?
Also, it recommends 'fusing each AC line conductor that is not at ground potential.' Will this requirement be satisfied by my main panel circuit breaker, or do I need actual fuses on the wires supplying incoming power from the wall outlet? As a follow up question, my garage breaker is 15 Amps, where in the KBAC manual a 25 Amp fuse or breaker is recommended for 110V usage. Will my 15 Amp breaker cause me problems being under the recommended limit for the VFD?
Lastly, while I'm on the subject, I purchased an Outdoor (orange) 12/3 extension cord which I had planned to cut off the female plug at the appropriate length and access the internal wires for connection to the VFD to supply incoming power from the wall. If anyone sees any issues with this approach, please let me know.
Thanks in advance for any help!
