Long time lurker, rare poster.
So, after Christmas, I figured a few of you have received a Work Sharp Ken Onion edition, and if you're like me, you immediately bought the Blade Grinding Attachment to go with it. I've been sharpening for many years, and my go-to was always my KME system. It does a great job. However, even with diamond stones, I was really tired of spending 30-60 minutes on any of the super steel knives we have. I don't find it meditative, as we have a 6 year old, and a free hour of time is hard to find. I've learned to freehand sharpen this year, and I've gotten decent at it, but it still takes a lot of time.
There's plenty of posts and YouTube videos about the WSKO and BGA, so I won't re-hash any of that, but I wanted to post my findings as a new user with plenty of "normal" sharpening experience.
Anyway, I hope this helps a couple of new users out. I've been having great success in 10 minute sharpenings with M4, M390, and D2 steels. Here's my Benchmade Super Freek in M4 that I did today (user knife, but it still got close to a mirror finish). This was its first sharpening since I bought it 6 months ago, it's only been stropped.
https://imgur.com/q2L0z1K
https://imgur.com/vqilZq8
I've really enjoyed the system, and having some freehand experience helps, but that flat reference plate is terrific for getting yourself straighted out every pass.
- First, everyone will tell you to start on a beater knife or two until you get your footing with the system. This is critical, but I'll add a couple of tips. Make sure your beater matches the stock type of what you'll mostly be doing. If you're doing folders, use a gas station folder. If you're doing kitchen knives, use a Wal-Mart Tramontina or something. Like for like.
- Don't use the slowest speed. The motor can overheat, as it's not drawing in enough air to keep itself cool. A lot of the failures you'll read about are due to this.
- Light touch. Just enough to contact the belt. I've found that the less you can deflect the belt, the faster it works. I use a forefinger-thumb grip near the tip of the blade, and as close to the heel of the blade with the other hand. Guide it gently with both hands to follow the shape of the blade.
- I find it easiest to be looking directly down at where the belt and blade are meeting. Looking straight down also helps you hold the knife straight.
- Don't pull the tip past the mid-point of the belt, just lift it away as it gets to the belt center. Common knowledge, but bears repeating. You'll also usually need to angle the rear of the handle fairly far away from the center to actually sharpen the tip. Probably more than you initially think. You'll hear the tone of the belt change if you go a millimeter too far.
- When feeling for a burr, remember that different steels create different burrs. I find the burr on M4 to be very easy to see and feel, but M390 is finer and requires me to use a light source to check for it.
- Smooth and fast. I think 1 second per inch is a bit slow. I tend to do more passes at a half second per inch.
- My best results have come from raising the burr on the coarse belt (same side passes until that happens uniformly), the same number of passes that took on the other side, then 3-4 alternating passes. Move to Medium, and just do alternating passes. Same with Fine and the Strop.
- You can add compound to the strop whenever you want. It's 12000 grit to start with, I added green compound to mine to coarsen it up somewhat.
- Use a belt cleaning stick from Menard's or Lowes to clean your belts (not the strop belt, though) every sharpening. It only takes a second, and they'll last a lot longer and work better.
- Don't pause. Ever. Blade is contacting belt, your hands are moving.
