Hello, I just received a controller from ebay to replace the old infinitely variable knobs on my duncan ceramic kiln. It came with the controller, solid state relay w/ heat sink, and a type k thermocouple with some ceramic segments to protect it. I plugged everything in and it ran fine at first, perfectly matched my thermostat at room temperature, clicked it on and felt the elements start heating up, left it for a few minutes heating up to a set value (SV) of 30*C to see if it would keep the temp consistent, and when I came back the kiln was still warm and I couldn't tell if the elements were on or not, but the measured value digits (PV) on the screen didn't read a number, it just said LL. I tried to unplug and plug it back in again, and the same thing came up. Pressed the set button to try to adjust the SV and i could, but for some reason the PV switched to -15 while changing the SV, then changed back to LL when I was done changing the values. Tried undoing and redoing the wires a few times to see if something was loose in the thermocouple or anywhere else and no change. The kiln is 240 and controller is 60-240 volts, but i took one hot wire and one neutral wire to the controller to make it 120 volts, just in case of power surges, and there haven't been any problems I can see with wires being loose or the controller switching off it the connection isn't quite right. Any help would be greatly appreciated, I really don't want to keep trying to use pyrometric cones to get O1 tool steel to work right, especially since the cone shelf came broken when I got the kiln.
This is the kit I received, maybe trying to save money on the most affordable one I could find was a bad idea for reliability? The model number is DTA-48. The manual, both paper and digital, has no information on troubleshooting.
http://www.ebay.com/itm/Pottery-Cer...roller-Kiln-SSR-Thermocouple-HS-/121098643288
