- Aug 2, 2005
I have been sharpening my own knives for a while now and always felt I did a pretty good job and had very sharp knives.
Recently I went home and began sharpening my mom's knife which had been very dull. I've never sharpend a very dull knife and quickly went to the store and picked up a small coarse grade/ fine grade diamond combination "stone" ( not a real stone but just had diamond coated plates for sharpening ).
I sharpened it the way I usually do which but found it was having difficulty cutting into the skin of some green peppers. I normally start at a coarse grade and move up but found I had to stop at 750 grit to get it to really cut through well. Funny thing is I have this exact same knife at home and usually never have this problem.
I came home and started cutting some mangos I got from my mom and realized I couldn't break the skin with any of my knifes. After some experimentation this is what I found:
My normal way: 1000 grit then do 6000 grit ( knives with good edge already )
New way: 350 grit then 750 grit
I tested using the mangos, tomatoes and paper.
Old way cut through tomatoes and paper smoothly but not mangos.
New way cut through everything but not smoothly through paper.
I know that you should sharpen your knives depending on the purpose, but It seems odd I can't find a good balance. The rougher grit cuts through everything but on some things it seems not as smoothly. Also, if you only need to go to a very coarse edge knife, why go up to 1000 grit, 6000 etc? I know many people go up that high or higher to get a very polished smooth sharp edge.
Is their something I'm not doing when using the higher grits to get it to break the skin of tougher fruits?
When do most of you guys stop?
thanks for the help!
