Hi,
I have a relatively inexpensive set of kitchen knives and the paring knife is about as dull as a butter knife on a good day. My issue is that almost every knife in this set has what I will call "micro serrations" that remind me of what the serrations look like on the cheap steak knives that come in cheap sets. I am wondering if I was to put this on say either my lansky or probably my kme would the serrations possibly damage the stones and if so what can I do to rid myself of the horrid serrations without buying more kitchen knives.( taking into account most of the other knives in this set at the same and will need a new edge at some point also)
Hehe,
How much is your time worth?
How thin are the edges, more like a utility/razor/boxcutter or like a true butter knife?
Yes, too much pressure will "damage" most stones,
as in cause them to release grit and lose material (wear).
So if you're talking diamond plates,
and you're grinding on the serrated side not the flat back side,
you have to go much lighter that the usual
less than half a pound amount of lightness you have to use with diamonds
otherwise you're losing diamonds and then you don't have diamonds.
But the good news you can just sharpen on the flat/backside,
like a regular knife,
So give it a try,
do say do 10 strokes, then use the lansky triangle stone to do a few strokes on the serrated side, and repeat 3-6 times, should take 2 minutes tops
The triangle stone is more resistant to wear than the other stones.
Or just give it a few (a dozen) pulls using the pull through tungsten carbide sharpener exclusively.
Non-serrated knives can be had for $1,
and if you're looking to have some
fun grinding out serrations by hand
a sacrificial sharpening stone can also be had for $1 at dollar tree at the moment,
put stone on shelf liner so it doesn't slip, two hands on the blade and grind away
