Instead of a pair of plates in the back with flange bearings mounted on them you could use a single plate, take the dimensions for the mounting holes for a direct drive motor from the EERF grinder plans and adapt them to the new single plate for the direct drive KMG clone.
That is exactly what I was thinking!!!! OMG you saved me some time! I was actually in cad making designs for almost the same thing lol. Now to find one with 5/8 and 3/4" shaft sizes!!Perhaps a simpler way to change to direct drive ( instead of taking apart and modifying the KMG) is to just remove the pulley and replace it with a motor coupling. Then the motor can be installed easily. It will also make for a smoother running unit vibration-wise and sound-wise.
Here is one similar to what I am referring to:
http://www.ebay.com/itm/LOT-3-FENNE...146?pt=LH_DefaultDomain_0&hash=item35b62157ba
Well, from an engineering point of view there is the problem of alignment. Even a fraction of a percent out of straight alignment will cause a huge vibration. Even if the noise and vibration isn't all that serious, the lateral force applied to the bearings on the motor and grinder will cause extreme wear, resulting in premature failure.
The shaft couplings like I linked to have a non-metallic "spider" ( often a hard rubber or plastic) that mates the two pieces attached to the two shafts.
Check your local pump or industrial supplier, they carry them in all sizes. At worst, you might have to buy one of each size and make two 5/8-3/4 pairs. Call the seller to check, but from what I have seen you can mix and match the pieces.
Stacy,
I think you have mis-understood me, or I'm not being clear enough.
The standard drive wheel on a KMG is 3.875" diameter. I don't propose running a motor over nameplate rated rpm, so I'll assume a maximum motor speed of 1750 rpm.
A direct drive KMG with the standard 3.875" drive roller will produce a maximum belt speed of 1,775 ft/min.
Yet, a desired maximum belt speed would be somewhere around 3500 ft/min. To achieve this, the drive roller diameter would need to be changed to about 7-5/8", which is huge.
That is all that I'm trying to say. I'll leave it at that.
Mike LoGiudice
You could just mount a drive wheel to the motor and place it on the right side of the KMG and get the motor to spin clockwise
