- Sep 28, 2003
There have been some very good threads recently regarding critique and opinion. Whether a piece appeals visually is very subjective, however whether a piece is well made and constructed with expertise and skill must be capable of an objective appraisal must it not? Well if I work on the basis that it is then it would be interesting to gather a definitive list of those aspects of a knife that a user or collector appraises to see if it matches their expectations and requirements for "fit and finish" for a chosen application (use, presentation etc).
Now I am still learning how to truley appraise knives, but if I list what I initally look at, I would be grateful if others with more "real life" experience could add to, develop, or critique the list:
So here goes - in no particular order.... how "I" assess a fixed blade knife.
Probably missed some or not doing something I should, so contributions welcome.
Stephen
PS: This list deliberately excludes aseement of sharpness and blade strength etc.
- Balance - how well distributed is the weight, not too much in the front or back.
- Comfort of the Handle - There should be no sharp or uncomfortable spots in various types of holding position.
- How well is the guard fitted - a super clean and precise joint on the blade side - a smooth tranition or clean, crisp joint on the Handle side.
- Grind - is it symmetrical, straight, and even across all surfaces.
- Ricasso, and choil - a continuation of finish and attention to all edged and grinds around this area.
- Blade finish - On hand rubbed - is it consistent across the whole surface. Damacus - is the etch even, no "gaps" between layers, differential thickness not too great between layers.
- Blade - Look down the blade top and bottom to check for warp or wave.
- Handle Finish - move fingers over spacers, inserts, pins etc to check of continuity of surface and finish.
- Filework etc - check it is consistent and even.
- How well do all surfaces match and meet - continuity , symmetry and consistency in spacers, lining, expansion/contraction joints.
Stephen
