The saw in the Victorinox "Hunter" model swiss army knife works like a chain saw on bone! Plus the "Hunter" model has a field dress gutting blade as well. IMHO its the perfect hunters knife. I've used mine for several years now and I love it!,,,VWB.
Don't you have trouble with the knife getting all gooed up inside? Seems like a SAK folder would be hard to clean out.
What is the point of cutting the breast bone at all?
I just reach up in the chest cavity with both hands and cut the windpipe and all then just pull it out. you do have to be careful you are cutting blind, but it works well. Doug
I don't know why you need to cut the breast bone in the first place? I have never done it skinning and butchering a deer.. keepem sharp
I just use a knife to cut up through the breast. It cuts so easy I do not see why you would need a saw.
If you are using the blade to cut and slice and being careful with what you are doing you do not get that much garbage in a folder when field dressing.
In order to better clean out the body cavity, it's necessary to open the rib cage by cutting the breast bone. It takes a sharp knife and some effort. Be sure you have a good hold on the knife handle as slipping could be disastrous. I prefer to use some older leather gloves when I reach this point.
I'm probably going to start using some type of small saw to make this cut just to be on the safe side.
Watch the first part of this video to see what I'm talking about. Click here.
It is not necessary to cut the breastbone to clean out the body cavity. It is also not necessary to cut the pelvis on most big game.
Too many folks reading too many books....and believing that is the only way things can be done.
