I also experimented with laser engraving of color anodized titanium.
Anodization does not seem to have an effect on the process and engravings retain all quality and contrast nicely.
The knife is made of grade 5 titanium with 1095 steel blades and 18-8 stainless steel hardware (screws, standoffs). Since the blade is an assembly of smaller, weaker parts, The Titanium and 1095 steel have a spring temperament to prevent immediate breakage where stress is present.
The white Handle parts are polyethylene terephthalate that have been 3d printed at 100% Infill and converted into isotropic solids via baking the parts in fine compacted salt to increase strength and surface finish ability. In addition to being quite strong the polyethylene terephthalate is heat resistant, self fire extinguishing, non-toxic and chemical resistant. it can be cleaned with acetone.
The primary design challenge was in arranging the latching system to take all play out of the extended "ready for use" configuration while allowing unrestricted rotation of components into the "collapsed" configuration. I have been serviceably successful in doing so. Admittedly some luck may have played a part in this.
I will be carrying it and using it in a "pocket knife" role to asses it's performance and hopefully any design aspects in need of being improved upon will come to light.
Until then I'm interested in what "knife heads" think about it
-Joe
