what I need to know, since I'm not used to the kit game, is how much people need in terms of finish.
I know exactly what I need to do on the one simplicity order.
I've got a mini bolo and two 57s (convex EDC) sitting here roughly ready for me to add scales and pins and put them up, but ....
the bolo isn't too hard, it's a forge finish, so you should be good with the 320 grit convex edge to work with finishing with a strop bat and/or sandpaper.
The 57s are full convex grinds, but I'm not sure if I should send kits out at a 220 grit or 320 grit finish or if I should pull the blades through a full hand sanding to 600 grit.
