I am going to move out of state. Selling all my knife making tools / supplies for bargain price.
I will not ship the item, pick up only.
please PM/reply if you have any questions. I also have bunch of small items not listed on this list, feel free to ask.
most of tools are acquired around end of 2017 to early 2018.
tools
1. 2x72 Belt Grinder by brett (esteem grinder) with 2hp Leeson motor KBAC-27D, 8" poly wheel & tooling arm, double ended small wheel attachment
purchased 2300, asking 1000. free belts see supply section
2. Evenheat KF 22.5 w/Rampmaster with Bill Burk Mod
purchased 1076, asking 500
3. disk sander(rob nielsen). KB Electronics KBAC-24D AC drive 9987 w/ Leeson 1800rpm 1hp ac motor
purchased ~1k, asking 500
4. 10L dewar and Nalgene 4150-2000 Plastic Dewar Flask
purchased 315 asking 150
5. dewalt portable bandsaw (DEWALT DWM120K) + swag table
purchased 530, asking 250
5. WEN 12 in. Variable Speed Drill Press
purchased 227 asking 90
6. WEN 3410 3-Speed Remote-Controlled Air Filtration System
130 + many filters. asking 70
7. files
8. small size vices $10 each (has 3)
9. sears shopvac with extra filter, $20
10. buffer: XtremepowerUS 6 inch Benchtop Buffer Polisher Grinder Heavy Duty 2.5 Amps 3,450rpm 1/2 HP
purchased 91, asking 30
11. arbor press (HHIP 8600-0031 Heavy Duty Arbor Press, .5 Ton Capacity, 10" Height)
purchased 60, asking 20
12. two 18*5*1.5 aluminum block (no holes), $50 for both
13. unopened 3m 60923 filters * 3, $15 each
14. phr-1 RC tester $200
supplies
1. 2x72 belts
- scotch finishing belt * 1
- cork finishing belt * 1
- 320 grit J flex * 19 (aluminum oxide)
- 320 grit * 21 (aluminum oxide)
- 220 grit * 9 (aluminum oxide)
- 180 grit * 20 (aluminum oxide)
- 120 grit * 7 (Silicon Carbide)
- 60 grit * 6 (Silicon Carbide)
- 36 grit * 15 (Silicon Carbide)
2. sand papers
- All by rhynowet redline
- 80 grit * 143
- 150 grit * 81
- 220 grit * 85
- 400 grit * 35
- 600 grit * 45
- 800 grit * 48
thanks and happy knife making!
tools
7. files
supplies
1. 2x72 belts
2. sand papers
- 80 grit * 143
- 150 grit * 81
- 220 grit * 85
- 400 grit * 35
- 600 grit * 45
- 800 grit * 48
