- Oct 2, 2014
Hinderer Knives' XM-Slippy was designed to answer the high demand from the European market for a Rick Hinderer knife that could be carried in areas with more restrictive knife carry laws; as its name suggests, it is a slip-joint knife. The knife was debuted at IWA 2017 and is currently entering into its second production run. The XM-Slippy shown in this review is a first run knife and externally there is no visible change when compared to the second run. Designed to be as universally EDC legal as possible, the thumb disc can easily be removed for two-handed opening if required.
New Review Format 2018!
Tactical Reviews is known for very detailed reviews using many high quality images. This has meant quite a lot of scrolling to read most reviews. In the new format, the review contains 'responsive image galleries' to better display these images as a slide show with captions.
NOTE: Unfortunately these galleries cannot be pasted into forum threads.
(Wherever you see the 'Read MORE' marker, it indicates that the Extended Version of the review has additional content at that point. Viewing the extended version helps support further reviews, but please ensure you return to this Forum for comments and discussion.)
(Moderators, there is a reciprocal link at the end of every review on Tactical Reviews.)
A few more details:
For the following galleries please click
What's in the box?:
A good look round the XM-Slippy - Things to look out for here are:
Rick Hinderer's Thumb Disc:
The XM-Slippy with Thumb Disc removed:
This example has the VERY orange G10 handles, but the XM-Slippy is also available in much more neutral colours. The stonewashed steel pocket clip is fitted by default in the tip down position and is pretty thick and sturdy (also read 'stiff').
One design aspect needs a little more attention; the smoothing/easing of all edges. A very obvious example of this are the edges of the back-spring, and the bevelled edges provide shadow lines along the back of the handle. The fact all edges are eased/rounded gives it a distinct look and feel and a great comfort in the hand and pocket. Some might criticise the fact that the H doesn't look as tight as they would expect, but this is as it should be; the combination of the easing and the fact there is an internal stop-pin results in this appearance, the blade itself is spot on and perfectly positioned.
Peering into the liners, you can see the very end of the clip screws just coming through the liner, but there is no contact with the blade; it does mean the screws are as stable as they possibly could be as they fill the threaded hole completely.
The Hinderer adjustable thumb disc uses a small grub screw (0.035" Allen key) to secure it in place. The Thumb Disc channel is the same on both sides of the CPM20CV blade, forming a T-shaped section that the thumb disc slides onto. The thumb disc can be positioned anywhere along the channel, or removed, allowing the user to find the best location for them.
If you need to disable OHO or prefer the look without the thumb disc you have the choice as the thumb disc can be completely removed.
The thumb disc slot also acts like a large nail-nick giving you something to grip to open the blade.
Explained by the Maker:
The reasons for certain design choices may not be clear when simply looking at an object, so this section is intended to give an insight into the thinking behind a design by speaking to the designer themselves.
While at IWA 2018 I had the good fortune to be able to talk to Rick Hinderer about this knife.
[VIDEO]
Video Edited with - Cyberlink Director Suite 5 (PowerDirector 16 and AudioDirector 7)
Camera - Panasonic HC-V770 - Microphone - Tonor TN120308BL
The Blade and Handle Geometry:
Most knife specifications have a basic description of the blade geometry, but in this section I will be taking a more detailed look at geometry and balance.
Using a set of gauges and precision measuring equipment including a Vernier protractor, callipers, fixed radius gauges and the unique Arc Master adjustable radius gauge (the one that looks like a crossbow).
These measurements have been tabulated and are presented along with a few reference blades (8" Chef's Knife, 5.5" Santoku and the popular Fällkniven F1).
Key aspects such as the primary bevel angle, grind type, blade depth, blade thickness, length, weight are detailed, along with balance information.
The 'Balance relative to the front of the handle' tells you if the knife will feel front heavy, or if the weight is in your hand (a positive value means the weight is forward of the front of the handle). The 'Balance relative to the centre of the handle' indicates how close to a 'neutral balance' the knife has in the hand.
In the case of full convex grinds the approximate centre of the grind is used for the primary bevel angle estimate.
The blade is made from CPM20CV steel.
New for 2018! BESS Certified sharpness testing:
The BESS 'C' scale of sharpness, developed by Mike Brubacher (Brubacher Edge Sharpness Scale) will now become part of Tactical Reviews' knife testing process. Initially this will be used to verify the sharpness of the factory edge and allow the knife to be brought to a minimum standard sharpness before testing a blade's cutting performance.
The XM-Slippy's factory edge has an average BESS 'C' sharpness of 399. This was a show exhibit knife, so I would not comment on the absolute sharpness after all the handling and trying out it has had. As it was, the edge didn't appear to have any rolling or damage, and with this edge would slice 80gsm well enough although not the cleanest of cut.
For testing I have taken the edge to a 30 degree inclusive angle and a BESS score of 200, at which point it is shaving arm hair with ease.
Author's Statement for Transparency and Disclosure
The test sample/s featured in this article have been provided for technical testing and review by the manufacturer. Test samples are retained by the reviewer following publication of the completed review for the purposes of long term testing and product comparisons.
All output figures and test results published in this review are the sole work of the reviewer, and are carried out independently and without bias. Test results are reported as found, with no embellishments or alteration. Though best endeavours are made to maintain the accuracy of test equipment, the accuracy of these results is not guaranteed and is subject to the test equipment functioning correctly.
A few more details:
What's in the box?:
[VIDEO]
