I think y'all are right. I wasn't keeping the tip on the stones at the end of each stroke.
I was using both the corners and the flats.
Is a rounded tip easy to fix?
It depends on how bad. If all you have is the SM for sharpening. The easiest way would be to carefully grind the tip back to sharp with one of the hones in the flat lay down position.
If it is really bad you will need something a little more aggressive.
I have actually done this to a friends knofe as well. I used the groove side, on my SM brown. Good call BOG.
Here's a picture of it. How bad is this?
That's not bad at all. I can't recall fixing a tip like that on spyderco ceramics (haven't used them in a while), but on a water stone it would be easy peasy. Pick a point that will be the new tip and sharpen until you reach it. Sharpen "almost up to the tip" and you won't risk overshooting and rounding it off again.Here's a picture of it. How bad is this?
I would take a few strokes off the top of the spine and drop the tip a tiny bit.
It will be as good or better than new without whittling away at the length.
