A knife can be hard to sharpen for many reasons. It can be due to the blade and edge geometry and steel type and also be hard because of what the person sharpening is doing. Those are just a few examples.
Knowing these makers I would assume the knives in question have steel with easy grindability so we should be able to eliminate that as an issue. What approximate angle are you sharpening at, and approximately how much force are you using? Are you sharpening to a burr? Burrs are bad for a number of reasons so you want to minimize the amount of burr you raise to as little as possible. Are you keeping the angle consistent? Is there light reflecting from the edge when you look at it straight on?
I take serious exception to the statement that burrs are bad.
You sure do not want a burr on the edge when it is time to use it, BUT, the failure to get a burr on the entire edge on first one side and then the other is the single most frequent reason that people do not get knives really sharp.
If a burr is not raised ALONG THE ENTIRE EDGE, you have not ground down to the edge. The burr is your indicator that you are done on that side of the blade - remember along the ENTIRE edge, not just at one spot on the edge.
Then, and only then, sharpen to a burr on the other side.
Repeat until you have used the finest stone you will use. (Actually you really don't need anything finer than a Norton India stone - about 800grit - to get a shaving sharp edge.) Then with light strokes, and maintaining your sharpening angle, do several strokes on each side, until no or at least very little burr can be felt.
Then strop. Easiest strop to make - denim stuck down with double sided carpet tape, dressed with green or white stropping compound (very best - Rick's White Lightnin' - Google it)
DO NOT flip the knife at the end of every stropping stroke. If you do, you will anticipate that flip, and be dragging your edge at too steep of an angle towards the end of it, and thereby wreck the edge (I have seen dozens - maybe hundreds of people strop incorrectly).
Don't flip it at all. Just give it 20 firm strokes on one side being absolutely fanatical about maintaining the sharpening angle throughout the entire stroke, the repeat going the other way. Back to the first side 20 more, and the other side 20 more.
I have taught 100s of people from 9yrs old to about 90 to get edges that they could literally shave with following this procedure.
Do not be afraid that you will ruin the knife doing this. You will not, and even if you did, but learned to sharpen in the process, it would be worth it.
