I saw an ad today for some new Cold Steel knives made from Krup 4116 stainless steel. Is this a good steel?
I saw an ad today for some new Cold Steel knives made from stainless steel. Is this a good steel?
What knife are you looking at?
Cold Steel has several knives made in China from 4116 steel, replacing some older models that were formerly made of Carbon V.
Krupp has a steel plant in China now.Is this steel also made in China?
Thanks, Vassili.
1.4116Krupp has a steel plant in China now.
I doubt we can compare Buck 420HC with this thing, Buck has heat-treatment setup and controlled by Paul Bos.
Thanks, Vassili.
... Krup 4116 stainless steel. Is this a good steel?
Cliff, are you saying that 4116 is better than 12C27M as a general purpose SS blade steel? (I mean, just ballpark it.)It has a very similar composition to 12C27M (has the same carbon/chromium amounts), one of the very well regarded stainless steels used by Sandvik and very popular overseas.
4116 ads a small amount of vanadium to act as a grain refiner and molybdenum to increase the secondary hardening responce. Both of these will also add slightly to wear resistance.
-Cliff
4116 is a fine grained, stainless steel made by ThyssenKrupp in Germany and is used for hygienic applications (medical devices and the pharmaceutical industry) and food processing which make it a superb material for kitchen cutlery. The balance of carbon and chromium content give it a high degree of corrosion resistance and also impressive physical characteristics of strength and edge holding. Edge retention in actual cutting tests exceeded blades made of the 420 and 440 series of stainless steels. Other alloying elements contribute to grain refinement which increase blade strength and edge toughness and also allow for a finer, sharper edge.
You can't believe anything you read about their products (coming from them)... except their prices.I found the following on the Cold Steel website. Here's what they say about Krupp 4116:
What caught my attention is the claim:
By "440 series" I assume they mean 440A, 440B, and 440C. So they appear to be claiming that 4116 has better edge retention than 440C !
There are so many factors affecting 'edge retention' that claims of one steel over another are kind of meaningless. I believe that 420HC out-performed 440C in Buck's CATRA tests, and that is one reason why they chose that steel. I have a bunch of CS knives, including some in mystery '400 series' stainless steel, and they all cut.
Point taken.
Still, it might be worthwhile to look at what knives CS uses this in. I went to their website and looked at what I could find in 4116. Nothing spectacular. The knives that one would expect edge retention in are in VG1 or AUS8. The real tough blades are SK5 or 1055. That leave some oddities in this steel. "Combat classics in Krup 4116 Stainless"? I wouldn't buy those patterns no matter what steel they were made from. All pigstickers. Used for punching holes in stuff. You could make them from 420J and they would still perform their intended function.
