Time to bed the tang. Or is it bed the handle? Not even sure if bed is the right term. Maybe a gunsmith can shed some light on the proper terminology. Anywho, I use to do this with petroleum jelly but Nick Wheeler (guess you guys know by now where I get a lot of my inspiration
) said he used wax (Johnson in his case) so I thought I'd give it a try. This one is Antiquax, containing carnuba and bee's wax. It's what I had on hand and it smells nice.
You apply a thin layer on anything you don't want the epoxy to stick to. I am putting on a very thin coat to hopefully get the best fit. If all goes well I'll have put on enough for the epoxy not to stick too. Fingers crossed.
After I applied some to the faces of the vertebrae, I clean up the inside really well with acetone. You want to make sure you get the best possible adhesion in there.
Mixed some epoxy (the 5 minute kind), filled the cavity and made sure it was aligned properly.
Now we wait for it to harden. I really hope Nick is right. Well I know he is right so I think it's more that I hope I did it right. If not and it sticks...let's not go there, positive thoughts Patrice.
Nick is the man! Boy did it work great. :thumbup: Popped right off, exact fit and a lot less messy than petroleum jelly. Sanded everything flat and this is what it looks like.
We do the same with the second vertebrae. Just a little harder to align right hence the use of the other man's best friend: Duct Tape.
This is what it looks like with the spacer between the vertebraes.
I did the wooden part of the handle last cause I wanted to be sure the wax worked properly first. Cheaper to redo the vertebrae in bovine ivory than that nice piece of redwood burl.
Posted this pic not because of the process which is the same but to show the exacto knife. I found that it was the easiest way to put the wax on there, especially in the inside cavities like the guard. Of course this is way too much wax, you wipe it down after you are sure you have some everywhere. You only need a thin film so you get a nice tight fit.
Another pic that is repetitive but I wanted to talk about the handle fit. The inside fit was pretty tight to start with so I had a hard time getting the epoxy to flow to the bottom of the cavity.
I need to leave a little more room or find a way to heat up the epoxy a bit so it is thinner and flows better. Or both.
Next we'll start work on the pommel.
Stay tuned.
