I thought to ask this from here, even though it's not quite knifes I am making, but you people seem to have vast metallurgical knowledge and experience, and I was hoping you could shed some light on this topic.
I have been jumping between S7 and L6 steels for making punches and various other parts that do not contain cutting edges. The work would primarily be cold work, but high shock and at least good abrasion resistance is warranted. On Charpy V notch test, according to matweb, L6 ranks at 5J, while S7 goes for 16J at the same hardness (57), but for unnotched samples, they both rank around 300J. The CVN value is the only thing that troubles me a little here.
I have been turning towards L6 due to availability. For me, it is readily available cheap, but for S7 I would have to order overseas, and pay more shipping than the value of the product, but in case L6 turns out not suitable, I have to pull that off.
I was thinking if I could improve the toughness with isothermal quenching. I have done some tests and found it a potentially good solution, it seems to reduce warping and produce more tougher parts. I have used 50:50 KOH:NaOH as quenchant, it melts at around 160-180C and remains good to at least 350C, haven't tried further, but sources cite up to 500. A salt mix of ZnCl2, NaCl and KCl in ratio of 68.6 + 7.5 + 23.9 produces an eutectic with mp of 200C and should be good up to 850C, but as I happen to have a lot of caustics, I tried it first.
When looking at the attached chart, am I on the right track to see that the "B" section means bainitic region, and in order to obtain bainitic structure with L6, I would have to use at least 250C bath to quench, and soak the parts minimum of 10 minutes and up to 100 minutes to complete the major lower bainitic formation? Are the benefits for impact strength potentially worth the procedure, or is the difference so small I would instead benefit from simple air blast quench and ordinary tempering cycle? I am looking to obtain above 50HRC.
