glass works in a pinch, but anyone with minimal shop knowledge should ditch the wasteful and slightly hazardous broken glass method and make a couple cabinet scrapers, or card scrapers as earlier poster called them. if you want the "finest curls" of hickory, make a cabinet scraper. the edge lasts a lot longer than the edge on a piece of glass, and you can burnish a new edge in less than two minutes once it starts to cut less efficiently. you can use old handsaw blades, quality steel paint scrapers, pieces of large crosscut saws work well. using thick steel, like circular saw blades will work, but create very stiff scrapers and are harder to work. the blade stock should be MUCH thinner than 1/8"..closer to 1/32" makes better scrapers. a fine scraper would be around .025 to .035, and an aggressive scraper would be somewhere between .040 to .080
very easy, take an old back saw(miter box), or regular rip/crosscut hand saw blade, and cut out index card shaped rectangles, or any other shape you might find useful. use a file to flatten one or two of the edges, and burnish them at a slight angle(10* approx.) with a hardened steel rod, a quality round screwdriver shaft will work. i use a tapered bolt hole alignment tool as a burnishing tool. this creates a lip, or raised edge on the corner, which when held at a 45* approx. angle and drawn down the work piece, "scoops" a nice even layer off the workpiece. you can make them super aggressive for thinning handles, medium for finer shaping, and fine, which will create a finish close to 400g sandpaper or so. when done right, little or no sanding is needed after. the scraper is bendable also, so it doesnt cut a flat line down the work, you can round everything off just right.
here is a video in making a large cabinet scraper, same exact principles used to make smaller scrapers.
https://www.youtube.com/watch?v=hq881txBKSw
another
https://www.youtube.com/watch?v=Y27MV0DQ9OI
another
https://www.youtube.com/watch?v=jVC37ToOjDU
they dont look very aggressive on a flat piece of lumber, but on a handle shaped piece, they can remove a lot of material pretty quickly. i never use glass anymore, and scrapers or essentially how i thin and shape handles(bought) now.
