open the box...use and abuse..repeat as nec... seriously though for a production made knife fallkniven is one of the best things going... laminated and convexed they sarpen and are maintained like any other convex blade..Great knives overall.
...is there special care needed in sharpening a laminated steel knife so as to keep the steel sandwich in the correct proportion?
Laminated blades are traditional for Japanese knives, actually solid steel blade is rare. This is why Fallkniven have laminated blades even with more or less regular steel in core. I do not see too much benefits from this, except using standard stock and being bit cheaper, but it is not different from use point of view then solid steel, for sure there is not difference in sharpening.
Only sides with softer steel may got scratched more easy.
Thanks, Vassili.
Using a thinner core for the edge and softer laminate sides makes the knife tougher. It's a little more flexible yet still incredibly sharp.
Also, it's not a cheap process to laminate steel.
have no fear, laminated blades as made/used by Fallkniven are solid.
I own an F1 and a PXL. Both are great knives and easy to cut with and are super strong tools. they are the best cutting knives i have had so far.
I use the PXL as an EDC. its very sharp and seems to want to stay that way.
so far the F1 is very handy at the cottage and on hikes in northern Ontario. its almost an EDC in some ways because of its intermediate size and not too great a weight. its also good with a firesteel.
all in all, the laminated blades are rock solid form my experience. you can pretty much abuse them at will (subjective, yes). wash them with dish soap, brush lightly with a diamond stone and they are good to go again.
the canadian distributor in BC is willing to do sharpening according to some emails i have exchanged with them. ask them or a similar distributor and see if you can ship yours for 'pro' sharpening whatever that means: http://www.workwearcanada.com/fallkniven/index.cfm
tougher than what?
VG10 is not super steel - it is about ATS34 - I can understand in ZDP189 is in core, but VG10 is not very exciting - same as AUS--8 in core in CS knives.
Thanks, Vassili.
Tougher then using a solid hard steel for the entire blade.
Japanese swords and cutlery were designed to be impact resistant and a little flexible. Also remember that at this time stainless steel wasn't a knife steel, and knife (blade) steel was high carbon, thus rust. Laminating the hard high carbon core with a softer stainless steel provided the flexibility and toughness needed while still remaining sharp and strong.
