- May 15, 2018
I have several stones and chosera I'd like to lap as regular maintenance, what does everyone use to keep their stones flat? I was looking at Atoma diamond plates but they are 70 a piece. Any feedback is appreciated!
Can I use this for all stones including chosera and all grit sizes without affecting the actual grit of the stones? My concern is lapping a 400 grit stone on the Naniwa and turning it into an 800 because I may have polished the 400 from lapping it.I use SiC on plate glass if I'm doing a ton of stones at once. Or I will use stearate-coated sandpaper on an 8x3 sanding block if I'm just doing a random lapping. The coating prevents the paper from loading so you can use the crap out of it. I also find the Naniwa SiC flattener to be excellent and it's only, like, 20 bucks, and if you ever need to flatten it (which you technically shouldn't), then you can just lap that on your sidewalk or something.
If I'm going high-dollar, I'll use a diamond plate, or the diaflat 10x4, but honestly, the three aforementioned cost-effective solutions provided me as good results. My JKI diamond plate actually proves to be the worst of all 5 of my options when working with extremely hard stones.
Gun-to-my-head recommendation?
Naniwa SiC Truing stone for its balance of ease of use, speed, versatility (you can employ SiC powder with it to increase aggression), final surface finish (a concern for higher grit stones), and cost investment.
I mainly use Atoma 400
Really, grit cannot be changed. Once it is mfg. with a grit it stays that grit. The surface can be affected, smoothed to 'feel' finer but the original grit remains the same. Then as you use it the stone will wear backCan I use this for all stones including chosera and all grit sizes without affecting the actual grit of the stones? My concern is lapping a 400 grit stone on the Naniwa and turning it into an 800 because I may have polished the 400 from lapping it.
to it's original 'feel'. On a ceramic and India stone this wearing back takes a long time. DM
Thanks! I can see myself grinding a stone away to dust. I'll be careful on over exaggeratingBe careful how often you flatten your stones I know some guys go over board when they not even close to dished and they end up removing more of the stone from flattening then do to sharpening.
I have found that Chosera's like to glaze or at least for me they have always been a pain that way and I just use a really fine diamond plate or a product called Rust Eraser that you can get from ebay just make sure they are Medium grit the fine won't do hardly anything,the Rust Eraser can also be used to remove filing's from the stone as well and it will remove less of the stone then a Nagura stone will.
$70 is inexspensive.I was looking at Atoma diamond plates but they are 70 a piece. Any feedback is appreciated!
