I also have a Venev 2000 grit stone and I still prefer the Suehiro G8 stone which is an 8K stone,the G8 stone is made from silicon carbide but it finish's just like an aluminum oxide stone so it will cut high carbide steels good.
I don't worry about steels that have vanadium carbides in them or any other carbides for that matter if I'm using water stones on them so long as I use diamonds or CBN stones first and move onto water stones,if you go up to the Venev 400 or even just the 800 you can still move to a finer grit water stone because your not removing much metal at this point so you don't need to worry if your cutting the carbides,when you need to cut the carbides is with your lower grit stones.
Maybe
HeavyHanded
can chime in on this as well because he also really likes the G8 stone,all I can say about the G8 stone it's the best 8K stone I have ever used and it does polish your edge for sure but it also still leave's a good amount of bite to your edge as well unlike others stones that polish.
