lawnmower blade steel is not a mystery steel. lawnmower blade steel is not an oil quench steel. if anyone had laid aside their pride and asked i would have told you. but you had to come at me with insults, insults are not constructive criticism. if you would have bothered to ask if maybe i had figured something out, instead i would have been all too happy to inform you
Lawnmower blade steel is not an oil quench steel, it is a water / brine quench steel. please stop insulting people and go test it for yourself
i have found the best results from heating my brine to about 130 to 145 F , and you have to get the steel to critical just like any other steel, when you go to quench you have to do it fast, water quench steel does not like to be put in slowly, you have to almost shove it in. test with a file, you should get a skating glass sound just like any other steel. i then temper the steel in a toaster oven at 325 for 2 hours per cycle and 3 cycles total.
i have made about 40 or 50 blades using this method, not one or two. so please go get a lawnmower blade and you try it for yourself
oh and quit assuming because you haven't been able to figure it out, someone else hasn't either.
and have a nice day
and have a nice day
