Leather IWB Bowie Sheaths
I really want to pick up a bowie for IWB carry, frog stud style. One of my worries is that a carbon steel knife would rust in the sheath if carried a lot and used little, especially in hot, tropical weather where I'd be prone to sweat.
Is there any way around this? Asian knives are often sheathed in wood, which works well most of the time, but I really like the feel and comfort of leather. I've carried in kydex before, but it just isn't the same. I do carry carbon steel balisongs in custom IWB sheaths and so far they've been fine, but it's only the tang that makes contact with the leather and I haven't noticed any moisture/condensation on the knives.
Aside from the above--who makes a good leather bowie sheath with a frog stud/button that won't break the bank? Being a southpaw, I'm probably going to have to go custom. I'd be looking to spend up to $100.
Thanks in advance!
In hot , humid weather, plus being inside the waist band next to the body at 98.6 degrees, you are always going to be liable for condensate rust regardless of what material the sheath is. If you sweat, the knife will also (probably).
There are a lot of good makers on this forum who could make the sheath for you. Your budget might be a little low, depending on the size of the knife, but you might start by reviewing the "Master List of sheath makers" which is a sticky at the top of this forum.
Good luck!
Paul
A Bowie knife worn as an inside the waist band? That sounds as a very uncomfortable and inconvenient way to carry a large knife. Is there any particular reason you wish to carry such a large knife partially concealed? To make such an item is no problem but the comfort issue would be rather doubtful.
Actually,
Bowie inside the waist band is a classic way to carry.
I have been known to tuck a full sized bowie inside the pants a lot. An alternative to his is to simply tuck it under the belt. Very convenient way to go.
The issue with rust and tropical environment is another question.
No real advice on that one. Just give it a try. If you want, you can give the knife a wipe down with an anti rust inhibitor. They make several great wipes just for that.
