So ive only recently gotten into making sheaths for my knives.  I did some research and watched a handful of how-to videos.
My process went as such:
Cut out the design
Transfer and cut out the leather (8-9 oz veg.)
Groove for stitches
Rollout stitch pattern
Cut and glue edge protection leather strip
Awl out stitch holes for sheath and belt loop
Dye the inside and outside of sheath and allow to dry (1-2 hours)
Stitch everything together (3-4 hours)
Dampen the sheath lightly to soften, insert the blade (i should have taped or protected it) and vacuum seal to form fit.
The sheath turned out beautiful. Blade on the other hand..... alot of dye from the sheath, and rust from the water.
The dye (fiebings) still has a tendency to rub off and its been a few days. Other than protecting the blade, is there anything else i can do to stop the dye bleeds? And now that its all put together what are my options other than cutting the stitches out of it? Thanks.....
Cut out the design
Groove for stitches
		 One I don’t dye the inside of my sheaths.   If your looking for color inside, I line my sheaths with leather that color.   With dye are you using an alcohol or oil ?   Fiebings makes both and both require good dry times.   The alcohol which I think your using cause you had rub off.  Is a powdered dye, so I use multiple coats with this.  First I condition my leather a couple times working it in well.   Then I start to lightly burnish the leather and let dry.   Then I add the coats of dye, one coat wait, second coat wait, etc.   Now I burnish with a like gum-trag.  When I have the look I want I then seal it.  Bag coat, tan coat , resolene.   When conditioning , dye , coating , remember take your time and let products dry.   Hope this helps again there are many more here with greater experience
