I have been making strops using leather belt blanks for some time. I usually use the smooth side, and I have charged the strops with diamond compounds from 10 down to 1 micron. I attach the leather to an MDF or plywood panel with double-sided carpet tape. The results have been pretty good, offering up brilliantly polished bevels and freehand BESS scores below 150.
I have noticed that the surface of the leather is rarely flat, with some surfaces never touching the blade. I tried to level one with sandpaper on a flat surface, but that didn't work so well as the leather didn't seem to be firm enough to take a level surface. I realize that doesn't make much sense!
I recently cobbled together a few strops using balsa wood and the same polishing compounds, and the surface can be leveled much better than leather. The balsa seems to be more firm and less likely to wrap around the apex if I get too enthusiastic and apply too much pressure. I'm thinking the balsa looks like a better alternative than the leather overall. The results are encouraging so far.
I would like to get more educated on the advantages of one over the other! Please offer suggestions and comments! I need all the help I can get!
