Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Yeah I downloaded that and it was set at 9999... do you have the owner's guide? if not, try http://www.paragonweb.com/ManualInfo.cfm?CID=103. it says to make sure ramp rate is at max(9999)
Do you know how many watts it is what the volume is? I just built one that is 3000 watts at .38 cu ft and it takes about 15 minutes to reach 1900Yeah I downloaded that and it was set at 9999... ![]()
3600 Watts, it’s a larger 36” deep 5.5” wide and 4.5 in tall chamber..Do you know how many watts it is what the volume is? I just built one that is 3000 watts at .38 cu ft and it takes about 15 minutes to reach 1900
Okay it looks like all the coils are glowing. Seems like just one coil.. do you think I should go another route if I’m looking to get into stainless? Or will this be suitable but barely? Plus the neck pain of length of time it takes. It seemed to hold 1950 no problem even after I opened the Door and shut it, seemed to recover pretty goodMake sure all the coils are heating. If one isn't working, it will take a lot longer.
The main issue is your oven is rated at 2000F max. The last little bit is a squeak on many ovens. It takes a good while to fully soak the bricks and get above 900F. I have an oven that has a 2000F rating and it will barely go past 1900F and ... won't reach 2000F at all.
Everybody is talking like 1 hr 15 minutes is too long for his oven to reach 1950F - what would the normal time for an oven to reach 1950F? Of course, that depends on watts and size of oven. I've got an EvenHeat KF18 and it will take well over 2 hrs to reach 1950F. I do have a couple of firebrick inside so the blades in rack are located right below TC tip and these firebrick does slow it down some, but not all that much. This is the oven I've got with .68 cu ft and 3120 watts:
https://usaknifemaker.com/evenheat-kf-18-heat-treat-oven.html
Anybody else have that same size oven that could give your times? The 1 hr 15 minutes of OP doesn't sound bad to me.
Same oven just about the same times--- for the last 20 years.
Ken.
Too fast to reach that temperature may result to cracks in the bricks especially when You have some water in it. I do prefer preheating My furnace with 2 hours from 20 to 200°C and run HT another day. I have DIY electric kiln and in version 1 I had reach time over 2 and half hours from 20°C to 1000°C. I made new heating elements for 3PH and now I can reach 1000°C in 40 min. but I don't do that. In HT is no hurry...just bought my first kiln. It’s an older model and a paragon KM36D. I just fired it up for the first time and to reach 1950 degrees took about 1 hour and 15 minutes, is this abnormally long? The unit seems to run great and hold a temp okay
