Let's check out the #Kansept Main Street
Do you use a knife when hunting?🔥
No matter what you carry on a hunt,
your loadout is always going to feel heavier in the middle of the day than it did when you left,
so each piece of gear needs to be worth every gram.
Let's check out the #Kansept Main Street 🔪 which one do you like best ?
DESCRIPTION
The Kansept Main Street, designed by Dirk Pinkerton, is a budget-friendly pocket knife that is enough for utility tasks.
The blade has a reverse tanto shape that pierces and slices with ease.
FEATURES
✔Utilitarian design makes the knife useful for all kinds of tasks.
✔Ergonomic handle for a smooth gripping surface that is comfortable in the pocket or hand.
✔Smooth thumb stud action is fidgety and easy to actuate.
✔Milled pocket clip is strong and holds the knife securely.
- Blade length: 3.36''/85.25mm
- Total length: 7.92''/201.27mm
- Handle material: G10
- Blade material: 154CM
- Weight: 3.95oz/112g
-Lock Type: Liner Lock
- Designer: Dirk Pinkerton
More details of the new models, check here: https://www.kanseptknives.com/pages/find-our-dealers
