Let's Talk about Buffers
Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
I have had a lot of emails and PMs about buffers lately, so I though it would be a good time for a discussion.
There are many pros and cons to buffers. The biggest Pro is they will bring a properly sanded surface to a shine quickly. The biggest con is they can tear a knife out of your hand and throw it quickly. These topics have been discussed at length and i suggest using the search engine to look at the past opinions on the subject.
With all the "most dangerous tool" and other talk, the fact is that most knife and machine shops that do any amount of work have a powerful buffer. The thing that makes it a dangerous tool is 50% setting it up right and 50% using it wrong.
Buffing in a Knife Shop:
There are three main things knifemakers buff - blades, hardware (guards, etc.) and handles.
I am not a fan of buffed blades beyond a quick pass on each side of the edge after sharpening to polish off the burr. I will leave the buffing of blades to a mirror polish for others to discuss, as it is the most dangerous use of the buffer.
Most hardware is small enough and non-sharp, so buffing is a good way to get it smooth and shiny. Remember that buffing is a polishing procedure and will not take the place of proper sanding.
Handles are where a buffer is a valuable tool. It will take a nice looking sanded handle and make it shine. It will polish ivory, and stag to a lovely glow. The trick is not over-buffing and avoiding any heat build-up. This is where speed will come into play.
SAFETY:
There have been many threads about buffer safety, but the biggest rules are
1) Buff in a clear space free of clutter and obstacles.
2) Buff with your elbows in and feet apart.
3) Wear protective clothing - long sleeves and a leather apron at a minimum. Wear a face shield or other face/eye protection. Wear dust/breathing protection.
4) Pay attention to the buffing task and do not have distractions around you.
5) Do not have pets and children in the shop when buffing.
6) Do not buff when tired,or when you have been drinking.
Here are some comments I made in replys recently:
A buffer is not necessary, but is very useful. Unfortunately, most people use one that is too fast, and is set up improperly. The best setup for amateurs is a 1/2HP 3Ph motor and VFD running a buffing arbor and turning 6" wheels. The arbor should be on a raised stand and not directly on the workbench surface. There should be at least 12" of clear space past the buffing wheels in all directions. A free standing pedestal is the very best setup.
The big 1HP buffers with 12" wheels are not for novices. They should only be used mounted on a rock solid pedestal.
Hand sanding will replace a buffer. The use of the 3M polishing papers can achieve a very smooth and fairly shiny surface. They go from 400 grit to 8000 grit. However, they won't get the glossy look a buffer will on some materials. Since that glossy look isn't permanent on a user, the slightly less shiny hand buffed finish is quite acceptable.
The biggest problem with people using buffers .. especially on blades and fittings … is not sanding sufficiently before buffing. The surface should be a perfect 800 grit or better before buffing. For a mirror polish blade, the blade should be scratchless at 2000 grit before buffing.
The alternative is a smaller and lower powered buffer. A 1750 or slower RPM 1/4HP motor with dual shafts and a pair if tapered spindle shaft adapters (L & R) used with 5" or 6" wheel is very tame. You can stop it with your hand if needed. I have one made from a 1/6HP 1050RPM motor that works great on handles.
The small hobby size jewelry buffers are good for handles and fittings:
https://www.ebay.com/itm/Jewelry-Po...=16349376628452bf3e821745472285ac50fc50d38e5d
The combo units are also good, and can do a few other tasks:
https://www.ebay.com/itm/110V-Upgra...899497?hash=item260da86ee9:g:rAkAAOSwgPBb0Vap
Of course, you can get a 3 phase grinder and add a VFD - This is a good option for the non-DYI flks or those with a big shop.
https://trugrit.com/product/3-4hp-1800-rpm-3ph-buffer-3-4-shaft-334b-54-lbs/
Here is my advice on designing and building a knifemaking buffer from scratch:
1) Buy a 3 phase 1750RPM motor around 1/2HP It could be as low as 1/4Hp for a small shop or as big as 3/4HP for someone doing more buffing and using larger wheels. TEFC is great, but even an open frame buffer will work fine if you vacuum and blow it out every now and then. While a 3500RPM motor will work, the chance of running it too fast is always present.
Power should be 120 or 240VAC. Get a cheap VFD to run it. This is a task where the normal Chinese VFDs work well. Depending on your google-fu and scrounging skills, this can run from free to $100.
2) Buy/make a buffer head. They are an arbor with a pulley in the middle. You want one in 3/4" diameter with a long shaft that puts the ends at least 6" away from the housing/bearings. The pulley is in the center. Some have a 3 groove pulley for speed change, but that isn't needed when using a VFD. A hardened and precision shaft is a must. These run between $50 and $150. Klingspor carried a wonderful one for $109, but I don't see it on their website right now (call or email them). Shop Fox makes the same arbor for $140:
https://www.grizzly.com/products/Shop-Fox-Buffing-Assembly/W1681
3) You need a pedestal for a grinder. It can be a stack of 2X8s to raise the grinder up off a low bench at least 12", but a dedicated free standing pedestal is best. You can build something from 2X4s using screws and glue and screw/bolt it to the wall, weld one up with a truck rim as the base, or buy one. The $50 pedestals at HF are sort of flimsy, but will work on a small buffer.
4) Room - You need clear room behind and below a buffer. At least 24" behind and 12" below are the minimum. More is far safer. A buffer on the shop floor takes up a 36X48" space
Buffing Speed:
I am one who prefers a slower buffer to a faster one. Most buffing I do is at 1750 RPM or less, often around 750 RPM. On some woods and ivories, I buff at 300 RPM.
Buffs:
There are many types of buffing wheels (buffs for short), and they all have their uses. I would suggest a new person start with a 50-60 ply 5" or 6" coton buff. If you are really cautious, start with a 4" buff.
Buffing Compounds:
There are hundreds of types of buffing compound. For handles, use matchless white or matchless pink. These eave the least compound on the handle. Watch buffing around bolsters and pins, as the metal will make a dark streak and darken the buff.
Clean up buffing compound on handles and blades with denatured alcohol and a clean soft cloth or paper towel.
Metal can be buffer with red rouge or green chrome. Avoid getting these on handles as the may stain the wood/ivory.
TIP - Tape off the metal when buffing handles and tape off the wood when buffing metal. Those sheets of decorative colored dot stickers can be put over pins to prevent streaks on light color wood.
Basic Cleanliness:
Clean the buff with either a buff rake or a buffing against large bastard file.
Use only one compound type on a buff if possible. It is OK to use white and pink on the same wheel, but don't use chrome and white on the same wheel. Store buffs in labeled zip-lock bags.
Vacuum up around the buffer. If putting a vacuum port to catch dust, it should be directly below the wheel and at least 6" away from the wheel.
If using an open frame motor, vacuum it and blow it out every week or so.
I am sure many others will have different methods and opinions, but this will get the conversation started.
I have the buffer spindle on my Burr King. It's very nice to have the variable speed. It's usually running at 40-50% on a 2500 RPM motor. Plenty fast
great info on buffers for those new to the game here. Very well worded and detailed. I used one of the big boys a few times, it sure did quick and great work on buffing the stag and ironwood i used on it, but yeah not for me. Picked up one of those jeweler buffers and could not be happier. Does great on handles, guards etc. cheap, safe, and takes up damn near no space. The jeweler's buffer should be in every knifemakers shop is my viewpoint after having one for 5 years. It def will not do blades though which is fine, i can live without mirror polished blades if it increases my chances of not shanking myself.
Buffers are dangerous. So are drill presses, belt grinders, bandsaws, and most other shop machines. All you have to do is learn to use those tools properly.
All this fear of buffers is ridiculous.
In the last few years we've lost at least 2 makers to buffer accidents. I don't think the same can be said for any other tool in the shop. I don't think there is anything ridiculous about it.
And I have used them for 40+ years and have all my digits.
All it takes is learning the proper way to use tools.
If these guys did not learn how to use them in shop in high school they really do not have anyone to teach them how to use a buffer.
I have been using a buffer since 1979 and still have all my fingers.
I think one problem is some stay on the buffer to long trying to remove scratches thet should have been removed in sanding.
The longer you are on it, the better chance of having an accident
Yes on more shop classes, and gym for that matter.
These pics are from when I set up the "buffer" I'm using. It is from a spare 2 HP 2850 rpm motor, yes it is overkill but it was just sitting there doing nothing. I mounted a die lock ring and some big plates on the shaft. The shaft is tapped so everything is held in place by a lock nut and smaller plate on a permanently fixed bolt in the tapped hole.
It is hooked up to my VFD, and I run it pretty slow (not even half of what the VFD can do) given the large wheel diameter.
If I had the room I'd probably get a proper buffer with a separate stand. But this motor just kicking around, and the possibility to control speed led me this way.
So far I only used it with the rock hard 10" felt wheel in the picture, loaded with green compound, for buffing/deburring edges. Great results.
Just ordered a bunch of 10" B, G, WDR and stitched cotton wheels along with compounds to try it on handle material and metal parts as well..
Hard felt wheels are great for mirror finishes.
Loose, floppy wheels are much more likely to grab work than the harder wheels.
Ok Bill, how about you share some of your pointers with the noob makers? I’ve found that keeping my work at 7 o’clock from looking at the spindle withthe wheel turning toward me a sisle wheel works great to de burr my edges. Polish any small parts and a I use a soft Muslim buff for handles. When I bought this buffer some 18 years ago, I didn’t know anything about them and found a 3450 rpm at a good price.. If I was to buy another I’d get a 1750 variable as Stacy has noted. I still have all of my fingers as well;)
As far as for safety- just don't present work to the buff in a way that it can be grabbed. Always keep the work below the centerline of the wheel.
Wear a dust mask or respirator when buffing. A good vacuum attachment will help keep your shop clean.
The softer your buff- the more likely it is to grab.
Don't use excessive pressure- it doesn't help the process and can cause grabbing.
The slower your buffer is, the safer it is-but too slow will impede the buffing process.
A "hood" over the wheel will catch/redirect much of the throw-off from the buff. I make mine from cardboard-it's safer than a metal hood.
I basically agree with what you're saying. But even if you remove the "emotion" of fear and examine the probability of different types of injury from different machines, the buffer keeps coming up on the short list of dangerous tools.
If you made a list of knife makers killed by drill presses and grinders over the years, is it nearly as long as the list from the buffer? Sometimes net effect trumps our "logical thoughts" about something.
Also, good pointers for working safely with the buffer.
Buffers do not kill people
People who are careless while buffing kill people
Word it however you like, the list of "people (knife makers in this discussion) who are careless while buffing" and lost their life is much longer than those "careless while grinding or drilling," to my knowledge.
Call it "fear," due concern, or whatever you can think of, but if I'm starting a new job and my supervisor shows me all the machines in the shop and they all have a list of people injured (minor or even ER visits), and one machine stands out as having multiple fatalities, I can tell you which one I am going to give much more "due concern" i.e. fear in some people's vernacular.
Not going to sit here and mince words over it, but if we replace the "dangerous" as in the "most dangerous tool in the shop" with "deadly" (most confirmed kills without a doubt), as in "most deadly tool in the shop," this discussion would be over immediately. Buffer wins hands down.
Unless I missed the grinder and drill press fatalities for knifemakers. Regardless, good discussion and I need to make a hood for mine.
Sam
Bench grinders wheels blow up, people go to the hospital all the time for a blade helicoptering in the drill press, lathes pull in people and sleeve their hands and arms, angle grinding wheels blow up. A belt grinder can grab a blade and thrust in into your femoral artery.
All theses things happen
Some of us have 40 years of safely using a buffer, we are the ones who know how not to get hurt.
Are you saying the buffer doesn't have the longest list of fatalities in the shop for knifemakers (which is who and what we're discussing)? If that is what you're saying, which tool is it?
I was always under the impression it was the buffer. This is thread drifting away from us, but I think that's an important point, no matter how many years of experience you have. Facts will be the same for 1 year or 80 years of experience. I know of several fatalities directly from the buffer, but absolutely none from the other tools for knifemakers.
If I'm wrong, do me a favor and show me which tool it is, aside from fast food. Much appreciated.
Sam
