Medx2018
- Sep 4, 2019
It discolors fasterGEC Micarta, not durable? Please explain.
In my experience it's been super durable, even when dropped off ladders
We call that "patina"It discolors faster
Tiger maple from CKs run a few years ago.That's a sharp looking knife. What scale material is that? Ironwood?
The bad part of micarta is that it absorbes dirt and moisture. Doesn’t go deep but it still needs to be cleaned occasionally especially if it’s animal fats and blood. The tighter the weave, the less prone to this problem as the resins soak in more thoroughly to fabrics like linen (as opposed to burlap or denim) during the manufacturing process.the nice part of the micarta is that you can liven it up with something as convenient as a high grit sandpaper
Absolutely wood absorbs oils as does bone. I just tend to think folks who buy micarta, especially with stainless blades, think it is a “ride it hard, put away wet” material. Folks tend not to realize how much gunk can get into micarta but take a toothbrush to it with a little soapy water and see how much crap you can work loose.Markeologist - Wood discolors too with age from oils in the hand and other things it encounters. Here is an example - GEC #93 Rams Foot with Cocobolo Wood covers. Pic 1 when I got it and Pic 2 after carrying and using it regularly.
Many woods darken quickly from oils, gunk, UV, etc... Cocobolo is notorious as well as a few others. Some not so much. I have a Bocote I've put through everything and it still looks almost like when I got it. Wood can generally be renewed for the most part too though. I tend to think most stag, ivory, and bone many times improves in appearance from handling and the elements. Just personal preference I guess.Absolutely wood absorbs oils as does bone. I just tend to think folks who buy micarta, especially with stainless blades, think it is a “ride it hard, put away wet” material. Folks tend not to realize how much gunk can get into micarta but take a toothbrush to it with a little soapy water and see how much crap you can work loose.
You’re correct, but only in an academic way. It would be unexpected that you’d be applying the forces necessary to see a failure at the choil. Off the top of my head, I’d guess your joint pin would sheer long before that happened.I know a sharp angle like at the bottom of a "v" is a stress raiser, which could lead to a broken blade.
Yup. With usage and exposure to UV-light, oxygen etc. wood will most definitely change color overtime. Your cocobolo is a perfect example - mine is not as dark yet but is on its way.Markeologist - Wood discolors too with age from oils in the hand and other things it encounters. Here is an example - GEC #93 Rams Foot with Cocobolo Wood covers. Pic 1 when I got it and Pic 2 after carrying and using it regularly.
GASP! That's gorgeous! When I saw this one I felt like Fred Sanford.... "It's the big one!"Knife content.
I'm comin' Elizabeth!GASP! That's gorgeous! When I saw this one I felt like Fred Sanford.... "It's the big one!"
It could just be me but, in my experience, GEC micarta has not been as durable as other covers. Is that your thinking as well or do you not care for the micarta aesthetics?
Yes. I'm one of those nuts that likes patina on my blades and not my covers. I'm just weird that way.
I’m salivating.This is what the trapper is for? Right?
Knife content.
