Lets talk underwear!
kgd
Not just any underwear. I want to talk about long johns. Long johns are one my most potent (in all manner of speaking) arsenals (yeah, I going on a limb with that word choice too) to combat the chill of winter. I wouldn’t be caught dead without my long johns on and will go so far to say that I even wear them in the late fall and spring when there isn’t snow on the ground. Long underwear provides several functions. The first is insulation and the second is moisture control. Good long johns will not only keep you warm they will help wick away moisture and function as part of a breathable layering system.
I wear my long johns over normal underwear. On top of the long johns can go various layering garments, whether it be mid-weight fleece, wool, vests or jackets. Because long johns are often next to skin and around joints like your elbows and knees you want the material to be skin friendly. Also, as an integral layering garment, you want your long johns to be skin tight but also flexible so as not to encumber movement. Long tops and pants shouldn’t be loose or baggy like your city pants. They should hug your body nicely. If you have love handles, then you should be able to see those love handles through the long johns, otherwise they are too big!
There are all kinds of long underwear and I don’t want to get into brands so much, but to talk about types and options. The first is the old 70’s waffle cotton. These are typically a 50% cotton/50% polyester blend. This is the kind you got when you were 6 and are still available in the local wallmart. They must be good for something because they’ve been around for 50 years, but I can’t quite figure out what they are good for. Maybe it is because every pair I ever owned was a cheap pair and like most cheap clothing they just don’t get the job done.
The bads on these are: 50% cotton. The cotton holds water despite the polyester content and wicking is very marginal and slow. As a test I just poured 3 drops of water onto the pair pictured below. The three drops of water spread into a quarter sized blob and just stayed there. On my high tech underwear, the same three drops were quickly dispersed over an area the size of my palm. Other bads are the thick seems. They claim they are flat but you can feel them when you are wearing them. They do provide pretty good insulation value when kept dry. So these are perhaps good for what they are intended to do. Wear them under a pair of blue jeans and keep you warm during your 15 minute recess at middle school. Aside from the price point, I really recommend not going with waffle cotton long johns.
A few years back, a family member asked me about a Christmas gift and I told them I wanted long underwear and a union suit. They went out a got me a nice Duofold union suit. First, I have to say that I love a union suit. With regards to long johns, having one piece is always better than having two pieces. The only exception to the above rule is when you gotta poop. Other than that, and hey you only poop once per day, I recommend going with a union suit if you have the choice. This duofold suit came of 50% cotton, 40% merino wool and 10% nylon. Like the waffle cotton, the duofold compromises on wicking/moisture retention on account of the cotton content. It actually did worse compared to the waffle cotton at wicking moisture from the sink drip test. However, this is a very warm combination. That warmth does come at a weight cost though. If you are layering this these things under a snowmobile suite and will not be engaging in high aerobic activity, then this is a good garment choice. I like to wear them for activities like ice fishing where I’m pretty sedentary and have all my warm weather gear on. For warmth they are just great and the price is just slightly higher then what you will pay for a set of the waffle cotton ones. It’ll keep you warm, just try not to sweat too much in it. Lets also hope you don’t fall through the ice eh?
Now going to my first set of high tech underwear. This set of long johns was made of 100% polyester. This is a set of underwear with different objectives in mind. In this case, the goal was to have something that was optimized for its wicking performance rather than insulation qualities. This pair is the one I referred to as wicking the 3 drops of water over an area the size of your palm. These long johns are a great system for high output activities and by distributing sweat over your body you allow that moisture to be evaporated into your outer layers or completely away from you body faster. Just try and get into a habit of shaking that weasel before putting it away during your little boys room breaks! Another good use for this is wearing set up is in your sleeping bag, especially if you are using a vapour barrier. This will help keep puddles of water from building up. Also makes your sleeping bag just generally more comfy.
Next set was a union suit made of similar materials. This one is 93% polyester and 7% spandex. Yes, now you know for sure, real men do wear spandex! As per my comments above, long johns that come in a union suit just work better for everything...Well everything except for that one thing...This union suit is my go to garment for most of my activities. This one is a bit heavier weight than the two piece suit and provides a good deal of warmth on top of moisture wicking. Since it is a single suit garment, I find the moisture wicking capability better then the two piece as you don’t get moisture collecting at the waistband areas of the garment.
My last piece of traditional long johns is the newest member of my growing underwear drawer. This is a set of merino wool underwear. Man this stuff feels like heaven on the skin. Moisture wicking appears about as efficient as the polyester and the warmth for weight is much better. This is the crème de la crème of underwear in my books. I’ve used it a few times over the past week and really enjoy the comfort. They seem warm, but I really haven’t used them in as diverse of conditions as I have my other long johns so I’ll reserve judgement on that later. As for price, these puppies go for about double what the polyester ones do. Are they worth it? I can’t honestly say they fully are. If you are looking for the best pair out their then I think they come close. At this point, I not fully sold on wheather a $130 is really a good deal for this set when the polyester set can be had for about 60% of the cost.
Still, its probably only a matter of time before I get myself one of the full woolpower union suits!
Last item, is really not long underwear but a layering garment. This is a fleece bib set up made of 200 wt. fleece and sports an outer flat polyester lining. This is an excellent warm weather garment to be worn over top of the long johns above. The flat, slightly slippery outer surface does not encumber layering other pants or shirts on top of this. The inside fleece is toasty warm and provides great surface area to wick away the vapour coming off your long underwear.
I’ve use a combination of long underwear (polyester union suit), the fleece bibs and mid 200 wt. fleece jacket under gortex jacket and shell pants in -30oC and have been perfectly happy with this combination. I've also used this same combination under a dry suit and found it to work well for that application and immune to the little trickle of water that inevitably finds it way inside your suit.
For this particular set up, the bulkiness of the fleece is tempered by the lack of arms which helps maximize movement under additional layers. The one piece pants/back also minimize cold spots in your lower back and guarantees sparring your friends and families the view of your hair plumber's butt. This piece sadly is no longer sold by the original manufacturer but one of my favorite outdoor winter layering items.
Now when you gotta poop with a union suit and a bib....Well, no getting around it...Its a pain. You gotta take off all your jackets and shirt and then the bib and union suit. Lets just say you don’t want to be caught in one of those ‘just in time’ situations.....Especially with all that wicking fibre about you!!!
Overall, I’m pretty happy with this combination of underwear. As I said, if I were to do it again, I may or may not pull for the high end merino wool set up. Then again, I wouldn’t start there, but I’d probably eventually get there. I still see that woolpower union suit in my future! But perhaps that is just because I love long underwear so much! I still haven't tried silk underwear yet. I gotta draw a manly line somewhere and I decided to do it at silk undies....
So lets hear what the rest of you have to say about long underwear and your preferences. Rather than talk about your favorite brand, what are your favorite textiles or combination of textiles and how do you effectively layer them for different kinds of activities?
i have a pair of mid weight long underwear form mec and i love them, they are 91% polyester and 9% spandex. i use mine a lot in the summer under my shorts on cooler days or nights while backpacking and a good pair will also help you stay cool on warm days
as my friend always says "its all about micro climates"
the paradox long underwear you get at costco are excellent and a real bargain.
92% polyester and 8% spandex. Really warm and comfy.
The top has a completely lined 1/4 zipper and the collar goes to the top of the neck, nice for venting and keeps my stanfield from itching.
40$ canadian for top and bottoms compared to hiking store brands and prices.
I really like my Merino Wool.
IBEX, Smartwool, Minus 33, Justin Charles all fantastic.
Filson is warm and comfortable but a little bit itchier.
I've used the waffle style and the poly ones and wasn't thoroughly pleased with either. A few years ago I stumbled across some Outlast ones on sale and gave those a try. They're my favorite so far.....the material in the ones I have is 46% Outlast, 38% poly and 16% wool. They do seem to work as advertised. If I ever get around to it I want to order some silk long underwear as I've heard a lot of good things about them and I've used and like silk neckerchiefs.
I like that fleece bib, I often look at those but I haven't pulled the trigger yet.
Thanks, keep it coming guys. Another thing I forgot to add. Pack an extra pair of uppers and bottoms or full union suit when camping overnight. That way you can change into a fresh and toasty long johns for the sleeping bag. If you roll up your old ones and throw them at the foot compartment of your sleeping bag, you might get them to dry out a bit in the night for the next day.
KGD,
Dang it! I saw the title of this thread and thought it was gonna be fun one...
I have been thru most of the same as you. I am currently using Capilene (silk weight). I wore the top for 30 days without washing it to test the anti-microbial treatment. It works extrmely well. I have been warned off, repeatedly, from silk. My next will be wool.
Merino wool ALL THE WAY. I have some patagonia capilene which I rarely wear. Honestly, the wicking performance between synthetic and merino is pretty similar, but merino wins in both comfort and STINK.
My capilene smells like death incarnate after a sweaty day of hiking, but my merino stays very fresh. A quick rinse in a stream and air drying on my tarp guylines, and my merino layers are like new. With synthetic, you need industrial strength soap and a class 3 biohazard containment system.
I've found the Gordini merino wool stuff to be a pretty great value. Much less expensive than smartwool or icebreaker, and it can often be found on sale or clearance at significant discounts.
Do the wool underwear garments shrink? If so, how much?
Can any of you provide a link or name of a vendor the you
bought from?
The Merino Wool items, that I have seen in pictures, seem THIN.
How thick area they compared to other underwear garments?
(I bought a Merino Wool sweater though mail-order, and it was real THIN.)
Ive used a lot of different long under wear and military issue poly pros and silk weight polartec (ninja suit) are the best I've used.
The poly pros are a lot thicker, but I do prefer the silk weight much better. The polartec silk weight underwear is thin, but is a great base layer and good for moisture wicking.
bought from?
They shrink a bit. You can't dry them in a machine dryer and they should be washed by hand or on gentle cycle.
They are thin. They are supposed to be body hugging and not like a sweater. As others have stated they possess good attribute at moisture wicking and also heat. I haven't tested them enough to figure out if the stink reduction is true or not. I generally don't smell, that or I don't mind my own smell that much :D
So, is merino wool the best base layer for our rough winters?
All I have at the moment is the army polyester one. Ok for spring and fall, but I wouldn't trust them for winter.
i can use icebreakers midweight merino wool in 30F and feel fine (while hiking).merino wool or bust.
for the poster whom entioned silk, i used that stuff in hawaii...its VERY lightweight and wicks wonderfully but it doesnt hold heat as well as wool....but it is a great lightweight alternative to wool for pajamas. they even sell silk sleeping bag inserts. i had some cool silk shirts i bought for $3 at the Salvation Army!!
