Local quenching oil worth it?
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by EntrancedVermin, May 28, 2019.
  1. EntrancedVermin
    EntrancedVermin Gold Member Gold Member
    270
    Jul 26, 2016
    Hello im Gabriel, ive been a hobbyist knife make for a few years now i mostly use 1084 and 1075. Im wanting to get in to 1095.
    So i called around a found a local place that has quenching oil they sell it to a local place that heat treat farm equipment blades. I got the spec sheet from them and it looks to be a 26 sec quench speed is this ever worth getting? Ive seen that 1084 needs a 11sec and 1094 needs 7-9sec.
    So is it ever worth buying a pile? They are only asking $25 plus tax so it might be worth trying?
    Ill leave the data sheet down below so someone smarter then me can look at it.
    Also what kind of steel do you think they quench with such a slow time.
    [​IMG]
    Thank you for your time,
    Gabriel
  2. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    I would not get it - too slow for knife steels.
  3. Larrin
    Larrin Gold Member Knifemaker / Craftsman / Service Provider Gold Member
    Jan 17, 2004
    That oil would be for high hardenability steels like O1 or L6, not your preferred 1075, 1085, and "wanting to get into" 1095.
    EntrancedVermin likes this.
  4. Drew Riley
    Drew Riley Riley Knife and Tool Knifemaker / Craftsman / Service Provider
    Oct 17, 2007
    Give Maxim Oil a call. They're based out of Texas, and if I'm not mistaken, still have the best price shipped for 5 gallons of Parks #50.
  5. dirc
    dirc
    Jan 31, 2018
    quick question, is L6 classified as a high hardenability steel because of the nickel? Outside of that, it's basically 1070 (or 15n20) with tiny amounts of vanadium, Cr, Mo, Si ... or is it the 0.7% Mn? ... I guess both the Mn and Ni?
    http://www.zknives.com/knives/steels/l6.shtml
  6. Larrin
    Jan 17, 2004
    dirc likes this.
  7. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    While a 26 second oil would probably harden O-1, 15N20, and 5160 in something as thin as a knife blade, an 18 second oil would be a better choice.
    I use Parks #50 for almost everything. I have medium speed oil on hand, but rarely use it anymore. Somewhere in the storage shed I have a pail of oil similar to yours and have never used it.
  8. MBB
    MBB Gold Member Gold Member
    244
    Apr 18, 2014
    I bought some of the 28 second McMaster Carr to try on stainless and other air hardening steels (with a coating). Works well for that purpose, stinks horribly, and I still clamp the steel between aluminum plates in a vice to complete the quench, so how useful it is is debatable. More of an interesting experiment.
    But totally useless for 1095. Call Maxim:
    http://www.maximoil.com/contact-us/contact/
  9. scott.livesey
    scott.livesey
    Nov 10, 2011
    If you are just a hobbyist and only doing a few knives at a time, go to the grocery and get some canola oil. Here in NC it sells for $5 a gallon on sale. Works ok on most steel.
    scott
  10. EntrancedVermin
    270
    Jul 26, 2016
    Thank you!
    I was assuming it was to slow but i wanted a second opinion ill be calling maxim oil today to order some parks 50. Ive been using canola oil but saw 1095 is better in a fast quench oil for full hardness and hamons.
  11. JTknives
    JTknives Blade Heat Treating www.jarodtodd.com Knifemaker / Craftsman / Service Provider
    Jun 11, 2006
    I also use parks #50 for most things, it is my favorite oil. I also have AAA but dot use it nearly as much.
  12. tkroenlein
    tkroenlein
    162
    Dec 10, 2016
    Engineered Lubricants (based in St. Louis) has better quenching oils than that for knife steels. I am using their Enquench Medium-2 which is 10.2-12.2 @ 78F. I am using it on 80CrV2 and 52100 with perfect results. They have another faster oil that compares to Parks 50. I think it's called EnQuench 303LH-9-11 (9.8sec) which is a tic slower than P50 according to the data sheets.
    It looks like the stuff you've posted is engineered for a specific customer and their needs.
Share This Page
