abbydaddy
- Oct 14, 2014
Hello All, I posted this review on my blog a little while back, but I wanted to make sure that Bill Had a chance to look it over and make sure that I wasn't speaking out of turn before I posted it here on Blade Forums (my reviews hit more eyeballs here than they do on my blog
). As per usual, this review was posted on my blog, so I try to keep the writing accessible to people who may not know as much about knives as those of us here on Blade Forums (and I am giving myself rather too much credit on that front
). I appreciate any feedback on how to make my reviews better and more useful. Thanks for reading
Introduction:
This was my dream knife, my holy grail, the white whale. And now it's mine. And it lived up to my expectations, and actually exceeded them.
If you want the TL;DR version: This knife is close to ideal for me. I love the looks, the ergos, the materials, everything about it.
The T series of knives was designed by Bill Harsey for Lone Wolf Knives. Lone Wolf Knives was a company based out of Oregon. Unfortunately that company is no longer around, so this knife is not being made anymore.
So the sad news is that I am reviewing a knife that you can't buy new, and in particular I am reviewing a version of a discontinued knife that was uncommon even when the knives were actually being made. Most of the Lone Wolf T series knives were made with black FRN (Fiberglass Reinforced Nylon) handle scales, not wood; and even among the wood handles, most of the handles were done in cocobolo, not walnut. Additionally, the T series knives came in a few different blade styles, and most of the knives were made with a center-ridged modified spear point design, rather than the full-flat ranger grind of my knife.
But let's get to the actual review. I'll come back to the topic of availability in the summary.
Let's start with the specs:
Specifications
Overall Length (inches): 8.80
Blade Length (inches): 3.90
Weight: 4.5 oz
Blade Material: CPM S30V
Blade Detail: Ranger
Blade Finish: Bead Blast
Handle Material: French Walnut
Lock Style: Liner Lock
Carry System: Pocket Clip
Frame: Stainless Steel
This is a big folding knife, though not ridiculously so. When I originally purchased this knife I had thought that the almost 4 inch blade would be bigger than I would want to carry daily, but since I already had the ~3 inch Fantoni I didn't want to get the smaller T1. My thought at the time was that I would have a very nice knife that I might use sometimes, since I really didn't think anything was going to shift the Fantoni out of my pocket long term. As it has turned out, the T2 has moved pretty much every other knife out of my pocket (other than for specific tasks). The 4 inch blade has proved to be an extremely useful and versatile size and shape.
The T2 is a surprisingly light knife for a steel framed large folder. It feels satisfyingly sturdy in the hand, but at ~4.5 oz, it rides in your pocket without trouble. Even though the T2 is a substantial knife, it doesn't drag your pants down.
The blade finish is a bead blasted finish. A bead blasted finish serves to create a visually pleasing and uniform finish that is also pretty non-reflective. I appreciate this finish on a "tactical" styled knife in stainless steel. I prefer the bead-blasted finish to a blade coating because the bead-blast serves to reduce glare without noticeably increasing the friction coefficient of the blade. I do not like the bead blast as much as stone-washed finishes for two reasons: firstly, bead-blasted finishes increase the likelihood of staining, though with CPM S30V that is not really too much of an issue; and secondly (and more importantly in my mind), the bead-blasted finish can really make any slip-ups in sharpening very obvious. Bead-blasted finishes are not nearly as bad as mirror finishes for showing scratches, but as I recently accidentally demonstrated, one bad stroke can make a pretty glaring mar on the appearance of the blade.
The handle material for this knife is French Walnut. Most tactical knives opt for a man-made material for the handles, as did most of the Lone Wolf T-series knives. Wooden handles might not be as tough as Micarta, G10, or FRN, but for everyday use the Walnut has held up just fine, it feels nice in the hand, and it is pretty.
The steel on this knife is CPM S30V, which is a particle super steel. These days S30V is not the most cutting edge super steel on the market, but it really isn't far off. S30V is still a very premium steel, it is essentially the stainless super steel that others are judged against. 10 years ago, when this knife was being designed and manufactured, S30V was about as good as it got, and really, if you're like me, then the incremental differences between high-end steels are pretty hard to actually perceive.
A Note on the Clip:
Usually I have a note on the sheath at this point, but this is a folding knife with a clip, rather than a sheath. The T2 has a large stainless steel clip that is surprisingly unobtrusive in the hand. The clip is not a deep carry clip, which means that about an inch of the handle sticks out of your pocket. The good thing about this type of clip is that the knife is easy to access, and if you are somewhere where knives can't be "concealed" then this helps avoid trouble on that front.
I have knives with much smaller clips that are actually more obtrusive when the knife is held, I feel like the size actually helps make the clip feel more like a part of the handle and less like a tacked on addition. In my hand the clip feels more like handle contouring than like a typical clip. The large clip also helps keep the knife securely in place without being too difficult to pull out/put in. For me, in terms of function and appearance, the clip is an absolute winner.
One last note on the clip, the clip is an obligatory tip-down clip. There are no holes for making it tip-up, and the handle scale is actually milled out to accommodate the clip, so you can't flip the clip over to the other side. Functionally, this means that for safety reasons, you are pretty much limited to right-back-pocket carry, or left front pocket (because it is a good idea to keep the blade against a seam in your pocket in case it opens in your pocket. You don't want to reach into your pocket and encounter an open knife). For me this is totally fine since that is what I like anyway, but for some people it is a drawback.
Review:
Steel:
The S30V steel is a very good steel. The blade has shown good edge holding and stain resistance while I've had it. I have nothing to complain about on that front. My only complaint would be that, as with S35VN, I have a harder time sharpening S30V than I do with less fancy steels. That is one of the things to bear in mind when buying knives with fancy steels. The same features that make super-steels better performing also make them harder to sharpen.
I don't know what the precise Rockwell hardness of the S30V used for the blade is. I have not been able to track down that info, and I do not have a tester of my own.
Blade Finish:
As I indicated above, the bead-blasted finish is not my absolute favorite finish, but it is fine. I do prefer the bead-blast finish to a blade coating for ease of slicing. In a perfect world, I would probably prefer a stone-washed finish on this knife, but I am happy with the bead-blast. The bead-blast is aesthetically pleasing, though as I said, when I messed up while sharpening my knife the scratches were very obvious.
Blade:
I cannot stress enough just how overwhelmingly thrilled I am with the blade on this knife. Size, shape, geometry, jimping, everything. The whole nine-yards. I like everything about the design of the blade on this knife. This knife has proven to be the most versatile knife I have ever owned. It handles kitchen work amazingly well for a folding knife. It even works well as a whittling knife. The full flat grind, combined with the drop point shape, makes for a truly effective and versatile slicer.
One of the things about the way that the blade is designed that amplifies the versatility of the knife is the the angle that the blade sits at in relation to the handle, and the fact that the knife is not a flipper. Flipper knives have a projecting piece of metal that serves as a finger guard, but in my experience those projections can also make it a little harder to use in the kitchen or for tasks where it is helpful to be able to bring more of the blade horizontal to the cutting surface. The lack of a flipper helps with this, but as you can see in the photo below, the angle of the blade makes it so that the pivot point of the handle actually sits above a flat surface. This gives your fingers a little ore room when working on a table or cutting board, which is part of what makes this knife such a pleasure to use. It is these sorts of subtle features of knife design that really make the difference in my experience.
Handle:
The handle of the T2 is the most comfortable handle of any knife I own, including fixed blades. This is pretty surprising to me considering that the T2 handle includes a large pocket clip and significant jimping. A big part of the comfort for me is that the knife is pretty ideally sized for my hand. In my review of the Spartan Difensa I described how I have a specific preference for knives that allow me to use my pinky to grip, and the T2 really allows me space and a shape that facilitates my grip.
Locking Mechanism:
The T2 has a sturdy liner-lock. The lockup is early enough that I am confident that there will be many years of life in the lock. The liner lock is my personal favorite style of folding knife lock. Other styles like the frame-lock (which is very similar to a liner lock), or the Axis lock (mostly found only on Benchmade knives due to exclusive licensing) may be more hip at the moment, I really like the simplicity and reliability of liner-locks. The other thing that I like about the liner lock is that it allows the handle scales to just be handle scales.
In the case of My T2, that means that the walnut handle is not just on one side. The knife is functionally a wooden handled modern tactical folder, which I think is awfully neat. I think that this characteristic of this particular T2 is also a part of why the knife does not seem to scare people when I pull it out to cut a string the way some other tactical folders do.
Fit and Finish:
The fit and finish of my T2 was fine, though (at risk of sounding like a broken record) not flawless like the Fantoni. The wooden handle scales are slightly offset from the frame, oddly the offset is opposite for the two sides, but the mismatch is less than half a millimeter on either side. The frame is also not fully smoothed on the blade side of the handle. Neither of these issues are significant, and neither affect function at all. At the original price that the T2's were sold at those very minor flaws would have been perfectly acceptable to my mind. At the prices I sometimes see Walnut handled T2's selling for these days, I might be a little upset.
Use Review:
The T2 has proven to be such a pleasure to use that I find myself using it even when I have knives available that are better suited for certain tasks, like cooking. After having the knife for about half a year I find that I am able to resist the urge to use the T2 for everything a little bit more, but I still find myself using it simply for the pleasure of using the T2.
Chances are good that if you live in a city or town that your pocket knife is mostly going to get used to open boxes and envelopes, and boxes and envelopes don't really require anything special out of a folding knife. But most people who carry a knife do end up finding that there are a lot of other times that pop up more occasionally where a solid and versatile knife is useful. Emergencies happen, sometimes you need to cut a strap in a hurry. When those kind of things happen it is good to have a solidly built and solidly locking knife with a good edge. Since I got the T2 I have not run into any emergencies, but I feel prepared when I have it.
When it comes to knife performance, I really like to see how knives do in the kitchen. The kitchen is one of the places where we tend to do most of our day to day cutting. That is why I have an assortment of nice kitchen knives. Of course having that assortment of nice knives means that most non-kitchen knives feel deficient to me in the kitchen. Not so the T2. I almost immediately found myself using the T2 in the kitchen more than any of my other folders, and for this review I went ahead and used the T2 as my only knife for making a meal.
(Review cont'd in next post)
Introduction:
Specifications
Weight: 4.5 oz
A Note on the Clip:
Review:
Steel:
Blade Finish:
Blade:
Handle:
Locking Mechanism:
Fit and Finish:
Use Review:
