Yes the 527 treasury series, Quite the size difference!! In that case a 501 would be even more massive.. most surprising. Thank you for the info!!If you're asking about the model 527 Treasury Series knives, they are the same size as the 505.
All the knives in this picture are 503's except the bottom knife which is a 505.
The 527, 505,506 525, 425, 424, and 283 are all small knives.Yes the 527 treasury series, Quite the size difference!! In that case a 501 would be even more massive.. most surprising. Thank you for the info!!
Thank you for all the model size info. Would you say the best in between size model would be the 501? Between the small 500 400 series vs the larger 112 110? Or is there other in between similar to the 501 size?The 527, 505,506 525, 425, 424, and 283 are all small knives.
The 503 is bigger, the same size as the 55 but still a smaller knife compared to the 110 and 112.
Great comparison photo, OB...good work.A size comparison for you.
The lines drawn on the paper are approximately 1 inch apart.
From left to right. 110, 112, 500, 501, 503, 055, 507, 524.
O.B.
That's quite a subjective thing as to what's the best , I especially love smaller knives.Thank you for all the model size info. Would you say the best in between size model would be the 501? Between the small 500 400 series vs the larger 112 110? Or is there other in between similar to the 501 size?
The blade is the same, but I ended up giving it to my buddy so I can't do a comparison.
