I have had a little trouble getting the new Pitman bushing, part #26, made. It is unusual for a bushing, since it is designed to rotate in the Pitman housing, instead of being pressed in. The wrist pin, part #29, apparently is designed to not rotate inside the bushing, since it is not lubricated. This is the opposite of how most bushings would work, with the bushing being pressed in and the pin rotating. The machine shop made it the normal way and had to remake it. It was my fault for not explaining the situation, but the fact that the oil hole does not penetrate the bushing and instead only takes oil to the outside of the bushing should have raised a red flag with them. In my old one, the pin was rotating simply from wear, however, and may have confused them. Also, your machine shop needs to be told that the bushing must be a little longer than the Pitman housing in the front or it will be clamped down tight and the bushing will not rotate when the washer and nut on the outside are tightened. This is critical and was also part of the remake of mine. Hopefully, it is correct now.
The new 9/16" set screws for the drive pulley came in. I am still amazed at the price of $15 each. The length of the set screws for the brake side of the drive pulley is really critical. I could only find them in 1 1/2" and 2" lengths. 1 1/2" is too short for one of them and 2" is too long and actually hits the top of the brake ring when the drive pulley is rotated. I had one old one that was 1 3/4" and it just barely clears the brake ring on rotation. If that set screw backs out at all, it will hit the brake ring and get sheared off, which must be exactly what happened to the one that I had to remove with an easy out that was broken off. Ideally, that set screw would be 1 5/8", and you better check them every now and then.
