Thanks for dealing with our pictures, Justin... =]
There are a few things we did on "Betty" that are different than what a person normally sees... some things done to replicate original engineering... some things done to work around realities. I've probably mentioned some of these earlier in this thread.
That's a funny motor mount...
Normally would have been a jack-shaft with two flanged pulleys on the mount and a belt running off the rear one, either down through a deck or floor to a line shaft, or up to a line shaft (I've seen pictures and drawings of both). One thing about a low drive-pulley configuration is its relationship with the mounting position of the idler/clutch pulley. There is a limited amount of swing when the idler/clutch pulley is mounted on the back of the hammer... quite a bit less than an over-head mounting position has. If the drive pulley is higher, the belt is shorter, and though the idler/clutch pulley is further from the belt, there is a reduction in total amount of slack (belt not touching a pulley) and the shorter throw of the idler/clutch is worked around. (The mounting bolt and nut of the idler/clutch pulley hits the frame and limits the swing arc). Our mount set-up approximates the drive pulley height a person would find on a self-motored model.
A person can see the jack-shaft is mounted on shim stacks. That lets a belt be continuous instead of spliced. We got lucky in that there was enough bolt length to both add and subtract shims (total height of stack to accommodate eventual 4% to 5% max. belt stretch). Even though I followed Western Belting's measuring instructions carefully, I needed to move the jack-shaft up another 1/4" to keep from smoking the belt and the hammer trying to run on it's own when it was supposed to be idling. For awhile, I intended to run a flanged pulley as the drive-pulley (like Bruce does). The 1/2" steel fingers either side of the belt near the 5" drive pulley is what makes this hammer run on a flat-belt pulley without hair pulling and fussing with alignment re-adjustments. The "fingers" are an "F" and the long leg is captured with a set-bolt, so the fingers can move both front/back and swing. Despite there being engineered-in flexibility of shaft alignment, these hammers (maybe just ours) can be picky about it.
There is an X,Y,Z alignment. Z is the hammer shaft (my view from the rear). The jack-shaft needs to be parallel to the hammer's shaft on all three axis. It can be left or right on the X, but left moves the belt closer to the idler/clutch pulley and maximizes amount of slack taken out for total amount of swing available. The jack-shaft bearing blocks have oblong bolt holes and that is the parallel alignment for X. The jack-shaft collar-stops align the drive pulley under the hammer-shaft pulley on Z. If a person looks at the cast mount under the box beam the jack-shaft sets on, there are shims visible between the motor mount and the back of the hammer frame. The mount, in theory, aligns the jack-shaft with the hammer shaft on Y by simply bolting it on. Everyone knows, "in theory" means not really. I've no way of knowing if our hammer is "peculiar", but no amount of fussing with jack-shaft alignment let our hammer run consistently without having the belt come off either the front or rear of the drive pulley. We fussed with shims under the top bolts of the mount until is was "best" and built the fingers to act like a flanged pulley and still be able to use a continuous belt... which we already had... along with already having the 5" flat pulley.
Why so much problem with the belt coming off? (Not the nature of flat-belt engineering, by a long shot). My guess is: Our hammer is nearly "out". I dial indicated total up-down play at the front hammer-shaft bushing and it was right on 0.025"... a number Sid at LG gave me as dividing line between "run it" and re-bush it ("Betty" gets a LOT of grease!). We believe the rear bushing is a lot tighter than the front bushing (not indicated, though we could have if I had thought of it, but it "feels" a lot less). Still, as our hammer runs, the hammer shaft at the front is in a lot of different places... the reality of which is it is never parallel X,Y with the jack-shaft, and what's a poor flat-belt drive pulley going to do about that? The fingers solve the "random alignment" problems. The belt doesn't run on the fingers... they keep the belt from moving around on the pulley as much as otherwise (most movement coming during start and stop). When running, the belt does what it's suppose to... climbs up the crown of the drive pulley and self-centers.
One aspect of our motor/jack-shaft mounting system is everything is part of the hammer. Originally I was going to mount the motor on the floor. I don't know if doing that would have expanded alignment problems or not... in theory, not... but... =].
Anyhow... that's a lot of yap for "Quick Reply". I'm happy to yap more if there is something my yapping might help.
Mike
