i am a relatively new to milling i have done some manually milled channel(brass and Aluminum) balisong handles and stuff and i'm looking to do some ti channel handles out of half inch round rod grade 2 titanium as i don't think i could mill much more than grade 2 on my mini mill
mechanically speaking what i need to do is mill a 3/16 slot down the middle of the rod then face mill the side of the rod so that the back is rounded and the side have a flat portion
iam looking for some advice on the following questions
-is my mill capable enough? as i have heard lots of other forums say it is
its a craftex cx605 from busy bee. same model as the more common x2
-what rpm should i use? it can go up to 2500 rpm by itself or would i need the belt conversion that lets it achieve up to 4300 rpm
-how fast should i go(feed)? is there a comparison to like (up the rpm but mill the same speed as aluminum) that type of idea as i will be milling manually
-will a hss end mill work as long as i use lots of coolant or will i need to get a 3/16 carbide end mill and will just a cheap carbide be sufficient as i will only be milling x2 at most x4 3/16 slots and will a hss be sufficient for milling the side flat and the previous question of will a cheap carbide be sufficient for making x2 sides for each piece flat(x2 pieces of .5 inch x 5.5 inch maybe 4 pieces )
-what type for drill bits will i need? will cobalt do or will i need carbide? i need to drill x2 3/16 holes all the way through for the pivots
any help or other advice would help tremendously and would be much appreciated thank you for any help and tips you might be able to give me
