Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Yes it isIt's very expensive, however.
@ nozh2002!
Thanks for the Link, i can not read unfortunately :grumpy:
Greets xxa
ZDP is not very corrosion resistant. One day out in humid and sweaty weather (clipped to pants) and it starts to have spots....
I would have expensive my :jerkit:The 4mm about 5/32 is about $75
Is BG-42 better corrosion resistant?ZDP is not very corrosion resistant.
ZDP-189/Cowry-X are both stainless steels with relatively low corrosion resistance and toughness, with high hardness and wear resistance. If you want high hardness and wear resistance, you might look into S110V (I don't know what availability is like right now though). However there are more balanced stainless steels like CPM-154 or S30V that you could look into for high wear resistance stainless steels, both are easier to purchase, heat treat, are tougher, etc. If you want greater toughness, edge stability, and ease of sharpening than those two, then you can move to 19C27 or 13C26. There are lots of good steels and it takes a lot of learning to figure out the proper application and heat treatment for different knives.
I currently own one ZDP-189 knife (Russell One-hand) and am very pleased with it. However, I also own several Japanese blades either laminated or plain. Frankly, I prefer the VG-10 other than cost. Beware, if you are successful in buying barstock ZDP-189 be prepared to get about 1/2 tool life in grinding it, and the frustration of finishing, it's a tough bugger to work with. You'll be lucky if you find any at all that is not heat treated, (of course the only way to begin) Japan is stickly about selling it unfinished.
